rhoSimpleFoam initialization with simpleFoal results
Old   September 13, 2020, 13:44
Default rhoSimpleFoam initialization with simpleFoal results
ishan
ishan_ae is on a distinguished road
Hello.
I am simulating subsonic compressible flow through a duct.
I plan to initialize the rhoSimpleFoam solution with that of simpleFoam.
I have a couple of questions for this approach which have confused me and slowed down my progress for quite some time:
  1. Would this be he correct way to do things?
    • Solving for turbulence, the usual u,v,w,P and then for T seems correct to me.
  2. Since the pressure field solved using simpleFoam is not pressure but kinematic pressure, how can I use this as an input to initialize the rhoSimpleFoam solution?
    • I ask this because for simpleFoam we will solve for kinematic pressure and not pressure. The units are different from that of pressure.
    • Do I need to multiply my simpleFoam kinematic pressure solution with the reference density before I input it to rhoSimpleFoam solver? This sounds complicated to me and I don't know how to do it.
  3. Mass flow rate or mass flow rate divided by density for flowRateOutletVelocity ?
    • My setup BC contain totalPressure at inlet and flowRateOutletVelocity. For simpleFoam solving, the flowRateOutletVelocity requires an input for volumetric flow rate and not mass flow rate. I have mass flow rate available with me.
    • At the outlet, I have estimated the density using isentropic flow relations. Would it be wise to divide the mass flow rate with this density, and then specify this as volumetric flow rate to the BC for simpleFoam solution or, should I supply mass flow rate as it is? The latter seems incorrect to me but I am not able to convince myself why so.
Some information on this would be helpful.
ishan_ae is offline   Reply With Quote
rhoSimpleFoam doubts on BC and fvSchemes (external aero) giovanni.medici OpenFOAM Running, Solving & CFD 3 October 27, 2021 06:06
Error Interpolating Results onto New Mesh nammeh CFX 1 March 26, 2019 13:08
Stall behavior w/ initialization from previous results lcbarreto FLUENT 4 October 17, 2017 12:30
Creating a tool to interpolate results Luis Batista OpenFOAM Running, Solving & CFD 2 April 11, 2013 09:15
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 12:33
