September 13, 2020, 06:13 |
Dtc moving hull
Githu Haridas
Hi All
I had run an analysis of DTC moving hull, and on the final result after analysis, a wave pattern is not forming, and the friction resistance value is cantinuesly varying, i had tried to troubleshoot the error and I couldn't solve, please help me in solving the issue. Please suggest a method for solving. |
November 26, 2020, 06:44 |
Tony Zhang
Rep Power: 6 |
could you specify what the problem is? maybe some images of wave pattern and values of fricitonal resistance?
hull, moving hull, trim angles, wave |
tutorial fluent Heave and Pitch Simulation of Ship hull moving through head sea waves | ksansandoval | FLUENT | 2 | January 4, 2021 01:23 |
OF Multiphase: interFoam-replace DTC Hull STL file with wigley hull | zyfsoton | OpenFOAM Pre-Processing | 4 | December 1, 2020 19:17 |
i can not find tutorial (Heave and Pitch Simulation of Ship hull moving through head | kerend | FLUENT | 23 | April 3, 2020 08:53 |
DTC Hull tutorial Error | cheljin1320 | OpenFOAM Running, Solving & CFD | 1 | February 26, 2020 20:51 |
DTC HULL post processing right setting | Raffaele Frontera | OpenFOAM Post-Processing | 4 | May 25, 2017 00:01 |
