Lagrangian simulation setup guidance
Old   September 7, 2020, 16:07
Default Lagrangian simulation setup guidance
Riddhideep Biswas
Rid@foam is on a distinguished road
Hello foamers.
I am doing a project on Electrostatic Spray Painting (ESP) in OpenFOAM using a solver called electrostaticSprayFoam which is a modified version of the original sprayFoam solver (just an extra electrostatic force is added, everything else remaining same).
I have chosen a paper for my validation purpose and it would be helpful if any one helps me how to setup the case in accordance with the paper (the link of which I have attached below) and answers some of the pertinent questions.
http://www.ilass.org/2/conferencepap...r%20M2-B-3.pdf
The questions are:
1)In the paper, they have done a steady state simulation. I have seen some Lagrangian steady state tutorials available in OpenFOAM-6 but the lagrangian cloud info. is not available for these simulations. So what should I do?
2)What injection model should I use. In the paper, no info. about the spray angle, injection velocity and other relevant stuff are given.
3)In the paper, the bell is rotating with a specified omega for which I have to apply a rotating mesh using dynamicMeshDict. If I do so, then what relevant forces (like SRF, nonInertialFrameForce etc.) should I include?
4)How can I visualise the parcel trajectories as given in figure 15 of the paper?
5)About the suface-film, what type of interaction (absorb, splash, rebound) should I use?
PS: I could not attach the paper because of its large size and only attached the link.
Rid@foam is offline   Reply With Quote
sprayfoam
Transient simulation CFX - BC setup Jared1986 CFX 8 June 15, 2017 06:52
Particle Size in Lagrangian multiphase simulation jhlee9622 STAR-CCM+ 2 July 20, 2015 23:15
How to setup initial pressure for an ABL buoyantBoussinesqSimpleFoam simulation leonardo.oliveira OpenFOAM Pre-Processing 1 November 20, 2014 12:17
Duct case setup - Fan simulation nkjsimulating Main CFD Forum 0 October 10, 2013 05:15
Concerning the setup of axisymmetry 2D simulation. Sirte FLUENT 4 January 31, 2007 17:23
