error in IOstream / help plz
Old   September 6, 2020, 03:53
Default error in IOstream / help plz
Park
Helpplz is on a distinguished road
I use openfoam v.7
My friends works well but only in my computer can find this error so I don't know the reason of this error
--> FOAM FATAL IO ERROR:
error in IOstream "/mnt/d/capstone/salome/running/11/center/stator/constant/polyMesh/sets/region0" for operation operator>>(Istream&, HashTable<T, Key, Hash>&) : reading entry
file: /mnt/d/capstone/salome/running/11/center/stator/constant/polyMesh/sets/region0 at line 108027.
From function void Foam::IOstream::fatalCheck(const char*) const
in file db/IOstreams/IOstreams/IOstream.C at line 109.
FOAM exiting
file: /mnt/d/capstone/salome/running/11/center/stator/constant/polyMesh/sets/region0 at line 423380.
FOAM exiting
region0
Renumbering cellSets:
Primary job terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
error in IOstream "/mnt/d/capstone/salome/running/11/center/stator/constant/polyMesh/sets/rotor" for operation operator>>(Istream&, HashTable<T, Key, Hash>&) : reading entry
file: /mnt/d/capstone/salome/running/11/center/stator/constant/polyMesh/sets/rotor at line 871133.
FOAM exiting
region0
Helpplz is offline   Reply With Quote
Old   May 12, 2021, 07:37
Serkan
sersol is on a distinguished road
I had the same problem recently. What I have discovered is that the problem emerges due to malaligned groups of faces in Salome. Just delete groups of meshes under the mesh (for example Mesh_1) and create a new group of faces. Hope this helps.
Cheers,
Serkan
sersol is offline   Reply With Quote
FoamExtend IOstream error in parallel WhiteW OpenFOAM Running, Solving & CFD 0 August 25, 2020 10:37
I'm newbie in OpenFoam plz help pmne324 OpenFOAM Running, Solving & CFD 1 March 15, 2016 04:41
[GAMBIT] Gambit Start Up error .... HELP PLZ! Abhya ANSYS Meshing & Geometry 2 July 12, 2012 01:40
plz help its urgent garima chaudhary FLUENT 0 September 25, 2007 06:28
plz ......help me out.....************************ krishna FLUENT 2 January 10, 2007 03:53
