How to add fvOptions into twoLiquidMixingFoam apps? |
September 2, 2020, 10:18 |
Lingfu Zhu
Hello everyone,
I am a new foamer. Iam using the OpenFOAM6. Recently, I try to add fvOptions(alpha1) into the alphaDiffusionEqn in the twoLiquidMixingFoam, the following error was showed when I wmake: alphaDiffusionEqn.H: In function ‘int main(int, char**)’: alphaDiffusionEqn.H:11:10: error: ‘fvOptions’ was not declared in this scope == fvOptions(alpha1)//add ^~~~~~~~~ alphaDiffusionEqn.H:11:10: note: suggested alternative: ‘fvOption_H’ == fvOptions(alpha1)//add ^~~~~~~~~ fvOption_H However, I added the fvOptions.H in the file my_twoLiquidMixingFoam.C at the beginning. As following: #include "pimpleControl.H" #include "fvOptions.H"//add this The file alphaDiffusionEqn.H I changed is showed as follows: fvScalarMatrix alpha1Eqn ( fvm::ddt(alpha1) - fvc::ddt(alpha1) - fvm::laplacian ( volScalarField("Dab", Dab + alphatab*turbulence->nut()), alpha1 ) == fvOptions(alpha1)//add ); fvOptions.constrain(alpha1Eqn);//add this alpha1Eqn.solve(); fvOptions.correct(alpha1); alpha2 = 1.0 - alpha1; rhoPhi += alpha1Eqn.flux()*(rho1 - rho2); } rho = alpha1*rho1 + alpha2*rho2; Any suggestions and commons are very welcome Thank you Best Regards |
twoliquidmixingfoam |
Adding temperature dependent heat source using fvOptions in chtMultiRegionSimpleFoam | shaileshbg | OpenFOAM Running, Solving & CFD | 14 | January 26, 2024 19:48 |
How to add a new material in the fluent Database | MikeITA | FLUENT | 5 | December 13, 2021 23:40 |
How to add source terms using fvOptions | noobFoam | OpenFOAM Running, Solving & CFD | 1 | June 29, 2018 09:29 |
Building a solver with fixedTemperatureConstraint using fvOptions | Fluido | OpenFOAM Programming & Development | 9 | February 15, 2018 01:30 |
Add Measure Markings or Coordinates to the Contour | Colin | FLUENT | 4 | August 25, 2004 10:54 |
