August 31, 2020, 16:18 |
Natural Convection - cavity - LES
Guilherme
Rep Power: 10 |
I have a small problem and I haven't found a solution until then... I'm running a LES case (WALE model) for a natural convection problem (buoyantPimpleFoam; Co_max = 0.5 and Pr = 0.7) and the velocity results are not good in the center of the domain (the opposite occurs in the profiles computed near the wall). On the other hand, the temperature profiles are very good! I attached some images. I believe that the problem may be related to the number of Prandlt being less than 1 (... since in this case the temperature is carried by the hydrodynamic portion), but I cannot say where I may be wrong. Best. |
August 31, 2020, 18:53 |
Rep Power: 14 |
Guilherme - it's difficult to comment without a little more information. What is the Prandtl number of fluid in the experiments? What are the different charts showing (what do 0.1, 0.5, 0.9 mean in the chart legends?). Long and short of it, though - if you have not matched the Pr number from the experiments, then you are probably not going to match both the T and velocity fields, since they will be diffusing at different rates.
September 1, 2020, 07:23 |
#3 | |
Guilherme
Rep Power: 10 |
Pr = 0.705
Both the experiment and the CFD tests have the same Prandtl number. And as you can see, the profiles, both temperature and velocity, are in agreement near to the wall... so the number of Prandtl is equivalent. The problem is at the middle of the domain (in this case, the velocity profile). Quote:
0.5 means being in the exact middle of the domain. Best. |
September 3, 2020, 14:22 |
Guilherme
Rep Power: 10 |
Anyone can help me?
buoyantpimplefoam, les |
Natural Convection in Cavity with Cu-Water NanoFluid | Ahmadreza_b | FLUENT | 3 | March 29, 2017 09:35 |
yPlus value in internal flow (natural convection in cavity) | tarunw | OpenFOAM Running, Solving & CFD | 0 | January 26, 2017 10:07 |
Problem in laminar natural convection in cavity | realfear | FLUENT | 6 | June 27, 2014 11:47 |
UDF for body force for rotating cavity with natural convection | s.jaiswal | FLUENT | 0 | February 18, 2014 03:01 |
natural convection in square cavity | Dhileep | Main CFD Forum | 0 | January 11, 2009 11:29 |
