Error while running compressibleInterFoam (Possibly because of wrong T BC)
Old   August 26, 2020, 07:05
Default Error while running compressibleInterFoam (Possibly because of wrong T BC)
Prasad ADHAV
Alpha001 is on a distinguished road
Here are my details about my system:
Kubuntu 18.04LTS
OpenFoam v7
Case set up:
I am trying to run a LES-VOF simulation for waterjet in an AWJC Nozzle, where the water jet velocity is 300m/s.
The phases are air and water.
I have successfully run a simulation with interFoam (incompressible case).
I want to run a compressible simulation for the same case set up.
I took the thermophysicalProperties, thermophysicalProperties.air and thermophysicalProperties.water from sloshing tank tutorial case.
I replicated p_rgh to p and added a T file sine there was none in the interFoam case.
The T file is as follows:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 300;
boundaryField
    wall
        type             fixedValue;
        value            uniform 300;
    inlet
        type             fixedValue;
        value            uniform 300;
    inlet2
        type             fixedValue;
        value            uniform 300;
    inlet3
        type             fixedValue;
        value            uniform 300;
    outlet
        type             fixedValue;
        value            uniform 300;
By reading a similar case , I think the issue is with the boundary condition set-up of the Temperature field, since I don't have any experience with any compressible cases.
Here is the error:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
Build  : 7-1ff648926f77
Exec   : compressibleInterFoam
Date   : Aug 26 2020
Time   : 11:35:03
Host   : "XDEM-laptop"
PID    : 17318
I/O    : uncollated
Case   : /home/prasad/01_PhD/3_Tutorials/3_trials/0_Nozzle_OF/Turb_1_300ms-1_compressibleInterFoam
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Selecting dynamicFvMesh staticFvMesh
PIMPLE: No convergence criteria found
PIMPLE: Operating solver in transient mode with 1 outer corrector
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
Constructing twoPhaseMixtureThermo
Selecting thermodynamics package
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          eConst;
    equationOfState perfectFluid;
    specie          specie;
    energy          sensibleInternalEnergy;
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::heThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::heThermo(Foam::fvMesh const&, Foam::word const&) at ??:?
#4  Foam::rhoThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#5  Foam::autoPtr<Foam::rhoThermo> Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMesh const&, Foam::word const&) at ??:?
#6  Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#7  Foam::twoPhaseMixtureThermo::twoPhaseMixtureThermo(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
#8  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/compressibleInterFoam"
#9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#10  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/compressibleInterFoam"
Floating point exception (core dumped)
I need suggestions. Please let me know if I should share anything else.
Thank you in advance.
Alpha001 is offline   Reply With Quote
Old   August 27, 2020, 22:08
shinji nakagawa
snak is on a distinguished road
Is your p file physically correct?
incompressible solvers use relative pressure.
compressible solvers use absolute pressure because the state of fluid is based on the pressure etc.
I am not sure what your picture means... It shows negative pressure, isn't it?
snak is offline   Reply With Quote
Old   August 29, 2020, 14:15
Bloerb will become famous soon enough
Try this:
     outlet
    type             zeroGradient;
    value            uniform 300;
Prescribing the temperatue at the outlet seems unnecessary for your objective and increases numerical instability since with inflow and outflow temperature prescribed there is no room for numerical error.
Bloerb is offline   Reply With Quote
Error when running pimpleFoam: wrong token type -expected Scalar ... 'nan' khronno OpenFOAM Running, Solving & CFD 7 February 19, 2024 02:31
[solids4Foam] HronTurekFsi3 Laminar Tutorial not running parallel using Foam-Extend 4.1? EternalSeekerX OpenFOAM CC Toolkits for Fluid-Structure Interaction 0 May 29, 2020 04:12
Self-Bailer Analysis Cd possibly wrong?? Armitage ANSYS 0 April 28, 2019 07:05
Wrong results from motorByke tutorial in OpenFoam 2.1.1 jsc OpenFOAM Running, Solving & CFD 3 April 16, 2013 08:26
star is not running the simulation in windows Arnab Siemens 1 August 2, 2004 03:40
