cma-permission-denied message for parallel running |
August 25, 2020, 22:22 |
sw choi
Rep Power: 6 |
Dear All,
While I am trying to run the parallel running (4 cpu case) from tutorial;/incompressible/icoFoam/cavityMappingTest; I have following error message. : In order to learn how to run parallel calculation, I am trying to digest the tutorial example. Error message; Finalising parallel run [DESKTOP-CHOIST:01362] 3 more processes have sent help message help-btl-vader.txt / cma-permission-denied [DESKTOP-CHOIST:01362] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages So, I also search this error message( cma-permission-denied) in google but I can't get a clear idea what is the problem. It would be great helpful to give me any suggestion. Thanks in advance. |
September 11, 2020, 10:47 |
lpp
Have you solved this problem?
September 12, 2020, 13:16 |
I resolve the problem for parallel calculation
sw choi
Rep Power: 6 |
I solved the problem based on the guidance from YouTube:
https://www.youtube.com/watch?v=uBIvhhtdHlg (this is lecture 1 out of 3) Please master to lecture 3. THis approach seems to be a little bit out of date but it helps a lot. For multi-region application, please see the following example; Allclean: #!/bin/sh cd "${0%/*}" || exit # Run from this directory . ${WM_PROJECT_DIR:?}/bin/tools/CleanFunctions # Tutorial clean functions #------------------------------------------------------------------------------ cleanCase0 rm -rf constant/polyMesh rm -rf constant/*/polyMesh # region meshes #------------------------------------------------------------------------------ Allrun-parallel: #!/bin/sh cd "${0%/*}" || exit # Run from this directory . ${WM_PROJECT_DIR:?}/bin/tools/RunFunctions # Tutorial run functions #------------------------------------------------------------------------------ # For meshing only #decompDict="-decomposeParDict system/decomposeParDict.6" # comment out runApplication blockMesh runApplication topoSet # Set initial fields restore0Dir runApplication splitMeshRegions -cellZones -overwrite cd system/water rm decomposeParDict ln -s ../decomposeParDict . cd ../solid rm decomposeParDict ln -s ../decomposeParDict . cd ../solid2 rm decomposeParDict ln -s ../decomposeParDict . cd ../.. runApplication decomposePar -allRegions #-- Run in parallel runParallel $(getApplication) #------------------------------------------------------------------------------ Note that I modeled two heater rods (solid; solid2) and you have to use -allRegion utility when you use decomposePar and reconstructPar I learn this method from OpenFOAM consultant. |
January 16, 2021, 08:00 |
Thanks choist31, that helped me.
August 3, 2023, 14:07 |
Madhav Ganapathy
Hey,
I referred the tutorial but I could not find any information that is of use. What did you exactly do to get it to run? Thanks |
error message while running job parallely | LYZ | FLUENT | 0 | February 6, 2008 23:20 |
Error message in CFX-10 | CFDworker | CFX | 2 | October 12, 2007 08:23 |
error message when running particles | Peter King | CFX | 0 | August 29, 2007 10:48 |
warning message: "your appear to be running..." | Wendy Liu | CFX | 1 | March 19, 2006 17:33 |
interface warning message when running parallel | Kang | FLUENT | 3 | November 23, 2001 05:32 |
