Convergent Nozzle Simulation
Old   August 23, 2020, 16:16
Default Convergent Nozzle Simulation
klitz is on a distinguished road
Hi everyone,
I am trying to simulate a NASA validation case in OpenFOAM. Link to case https://www.grc.nasa.gov/WWW/wind/valid/arn/index.html. I'm using the given 2D grid in the link. Boundary conditions are also given. My problem is that I can't reach convergence with or without turbulence on especially in pressure. I am using simpleFoam. Should I use compressible solvers or change some of the boundary conditions? Because I am not sure about the arbitrary flow(inflow in case dic) should be zeroGradient or not(in U). And since I dont know the inlet velocity how can I find k and omega(below i used 0.01 Mach to calculate k and exit diameter of the nozzle for turbulence lenght scale to calculate omega) ? Also, for turbulence BC's at wall should I use 1e-10(I have seen some threads not to use 0) or the values I find for the inlet? Below you can find the case directories:
Pressure
internalField   uniform 98588.02;
boundaryField
    inflow
        type            totalPressure;
        p0              uniform 183483.281;
    outflow
        type            totalPressure;
        p0           uniform 98595.03;
    Freestream
        type            totalPressure;
    v_wall
        type            zeroGradient;
    i_wall
        type            zeroGradient;
    BaseAndTop
        type            empty;
Velocity
internalField   uniform (3.48 0 0);
boundaryField
    Freestream
        type            inletOutlet;
        inletValue      uniform (3.48 0 0);
        value           uniform (3.48 0 0);
    inflow
        type            zeroGradient;
    outflow
        type            inletOutlet;
    i_wall
        type            slip;
    v_wall
        type            noSlip;
    BaseAndTop
        type            empty;
omega
internalField   uniform 8.2883133;
boundaryField
    inflow
        type            fixedValue;
        value           $internalField;
    Freestream
        type            fixedValue;
    outflow
        type            zeroGradient;
    i_wall
        type            omegaWallFunction;
        value           uniform 8.2883133;
    v_wall
    BaseAndTop
        type            empty;
k
internalField   uniform 0.04432;
boundaryField
    inflow
        type            fixedValue;
        value           uniform 0.04432;
    Freestream
        type            zeroGradient;
    outflow
        type            zeroGradient;
    i_wall
        type            kqRWallFunction;
        value           uniform 1e-10;
    v_wall
    BaseAndTop
        type            empty;
and also checkMesh -allTopology -allGeometry
Mesh stats
    internal points:  0
    edges:            297861
    internal edges:   58581
    internal edges using one boundary point:   0
    internal edges using two boundary points:  58581
    faces:            237420
    internal faces:   117780
    cells:            59200
    faces per cell:   6
    boundary patches: 6
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     59200
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Topological cell zip-up check OK.
    Face-face connectivity OK.
  <<Writing 6 cells with two non-boundary faces to set twoInternalFacesCells
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology                   Bounding box
    Freestream          320      642      ok (non-closed singly connected)   (-0.644917 4.16667 0) (6.66667 4.16667 0.0223293)
    i_wall              360      722      ok (non-closed singly connected)   (-0.644917 0 0) (6.66667 0 0.0223293)
    inflow              160      324      ok (non-closed singly connected)   (-0.645 0 0) (-0.644917 4.16667 0.0223293)
    outflow             180      362      ok (non-closed singly connected)   (6.66667 0 0) (6.66667 4.16667 0.0223293)
    v_wall              220      442      ok (non-closed singly connected)   (-0.645 0.08333 0) (0 0.354167 0.0223293)
    BaseAndTop          118400   119642   ok (non-closed singly connected)   (-0.645 0 0) (6.66667 4.16667 0.0223293)
Checking geometry...
    Overall domain bounding box (-0.645 0 0) (6.66667 4.16667 0.0223293)
    Mesh has 2 geometric (non-empty/wedge) directions (1 1 0)
    Mesh has 2 solution (non-empty) directions (1 1 0)
    All edges aligned with or perpendicular to non-empty directions.
    Boundary openness (-6.86038e-19 1.70069e-18 9.86545e-16) OK.
 ***High aspect ratio cells found, Max aspect ratio: 1008.9, number of cells 3
  <<Writing 3 cells with high aspect ratio to set highAspectRatioCells
    Minimum face area = 6.86882e-09. Maximum face area = 0.0691225.  Face area magnitudes OK.
    Min volume = 1.53376e-10. Max volume = 0.00154346.  Total volume = 0.679026.  Cell volumes OK.
    Mesh non-orthogonality Max: 70.7303 average: 9.90224
   *Number of severely non-orthogonal (> 70 degrees) faces: 1.
    Non-orthogonality check OK.
  <<Writing 1 non-orthogonal faces to set nonOrthoFaces
    Face pyramids OK.
    Max skewness = 0.780396 OK.
    Coupled point location match (average 0) OK.
    Face tets OK.
   *Edges too small, min/max edge length = 6.86878e-06 0.450016, number too small: 406
  <<Writing 406 points on short edges to set shortEdges
    All angles in faces OK.
    Face flatness (1 = flat, 0 = butterfly) : min = 1  average = 1
    All face flatness OK.
    Cell determinant (wellposedness) : minimum: 1.39417e-05 average: 1.14028
 ***Cells with small determinant (< 0.001) found, number of cells: 1223
  <<Writing 1223 under-determined cells to set underdeterminedCells
    Concave cell check OK.
    Face interpolation weight : minimum: 0.411365 average: 0.487032
    Face interpolation weight check OK.
    Face volume ratio : minimum: 0.69873 average: 0.947747
    Face volume ratio check OK.
Failed 2 mesh checks.
End
fvSolution
solvers
    p
        solver          PCG;
        tolerance       1e-10;
        preconditioner  FDIC;
        relTol          0.1;
        smoother        GaussSeidel;
    "(U|k|omega|nut)"
        solver          PBiCG;
        smoother        symGaussSeidel;
        preconditioner  DILU;
        tolerance       1e-10;
        relTol          0.1;
SIMPLE
    nNonOrthogonalCorrectors 2;
    consistent      yes;
    residualControl
        p               1e-6;
        U               1e-6;
        "(k|omega|nut)" 1e-4;
relaxationFactors
    equations
        U               0.45;
        omega           0.3;
        nut             0.3;
        k               0.3;
        p               0.25;
fvSchemes
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
divSchemes
    div(phi,U)      Gauss limitedLinearV 1;
    div(phi,k)      Gauss upwind;
    div(phi,omega)  Gauss upwind;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
I know it says 2 mesh checks failed but since they were able to obtain convergent solution I thought I would be able to get a convergent solution also. Dimensions of the nozzle is given in the attachments. Any recommendation would be appriciated.
Thank you.
klitz is offline   Reply With Quote
Old   August 23, 2020, 16:41
Domenico Lahaye
dlahaye is on a distinguished road
Definitely use compressible solver like e.g. rhoSimple. Possibly try some tutorials first. Make sure that checkMesh gives no errors.
dlahaye is offline   Reply With Quote
Old   August 23, 2020, 17:52
OK thank you, I will try compressible solver. I also tried with a mesh which did not help with the issues. Would you please comment on the BC's? To me U and p look appropriate for this simulation however, I am not sure about the omega and k BC's since I am not sure about which dimension to use for turbulent length scale.
Old   August 24, 2020, 02:51
Domenico Lahaye
Chapter 16 of 2. Moukalled, Manga and Darwish, The finite volume method in computational fluid dynamics, Springer 2015 , http://www.springer.com/gp/book/9783319168739
Old   August 24, 2020, 18:14
Thank you I will check the chapter.
Inverse Design Optimization khavart SU2 Shape Design 0 June 20, 2019 04:37
Simulation on CD Nozzle Praneeth Kumar FLUENT 2 April 29, 2019 04:06
CO2 nozzle evaporator simulation with RGP table lyfflynice CFX 12 October 25, 2018 03:05
Nozzle Simulation temperature Extrapolation Error xuexingyu24 CONVERGE 1 July 17, 2018 13:05
Need assistance in BC's for simulation of Vacuum cleaning nozzle bruce OpenFOAM Running, Solving & CFD 0 May 22, 2009 14:56
