fully developed turbulent flow at inlet using mapped BC
Old   August 21, 2020, 06:44
Default fully developed turbulent flow at inlet using mapped BC
atul1018 is on a distinguished road
Hello All,
I am trying to simulated particle-laden backward facing step (BFS) case using DPMFoam. I am using mapped BC to provide fully developed turbulent flow at inlet (with centreline velocity as 10.5 m/s and average velocity as 9.39 m/s. To map the flow field, I am taking offset of 0.067m from inlet but unfortunately I am not getting fully developed flow at inlet with centre-line velocity as 10.5 m/s and average of 9.39 m/s. The peaks of mapped velocity at inlet is is 11.13 m/s *more than 10.5 m/s) and also the mapped velocity field does not satisfy no-slip condition (velocity at the wall are not zero). the the settings for mapped BC are as follows:
In blockMeshDict:
    inlet
        type            mappedPatch;
        sampleMode      nearestCell;
        sampleRegion    region0;
        samplePatch     none;
        offsetMode      uniform;
        offset          (0.067 0 0);
       /* type    patch; */
        faces
            (4 7 3 0)
In U.air
inlet
        type                mapped;
        value               uniform (10.5 0 0);
        interpolationScheme cell;
        setAverage          true;
        average             (9.39 0 0);
In omega.air
inlet
      /*  type                zeroGradient; */
          type                mapped;
          value               uniform 129.448;
          setAverage          true;
          average             129.448;
In k.air
inlet
        type                mapped;
        value               uniform 0.331;
        setAverage          true;;
        average             0.331;
I am also not sure about the meaning of certain keywords(value, average) used in mapped BC. I am hoping to get some idea about mapped BC to provide fully developed turbulent flow at inlet.
Best Regards
Atul
atul1018 is offline   Reply With Quote
mapped bc, turbulent flow
UDF for fully developed turbulent flow at inlet soroushsaberi FLUENT 0 May 28, 2014 18:00
Fully developed flow inlet Pleb STAR-CCM+ 5 November 25, 2011 12:25
BC for fully developed turbulent flow in a pipe mmd014 FLUENT 2 May 22, 2009 07:50
fully developed turbulent channel flow pankaj saha Main CFD Forum 0 August 24, 2007 19:15
profile for fully developed turbulent duct flow jeff Main CFD Forum 1 November 14, 2001 22:35
