#1 | |
Muhammad Kashif Jawad
Rep Power: 5 ![]() |
hi everyone!!!
when i run the case i get this error, and i'm unable identify the error. please help me identify this error. I'm attaching my files as well test208.zip I get this error on the terminal.. Quote:
#2 | |
I figured out the above error, it was actually error in my alpha.water file
i used internal filed zero/0, but when i changed it from 0 to 1 it worked. But now i came across with another error, after running the solver, after few iterations i'm getting this error. Quote:
PIMPLE: iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 0.00118277, Final residual = 8.74049e-009, No Iterations 2 Phase-1 volume fraction = 0.526704 Min(alpha.water) = -6.57072e-016 Max(alpha.water) = 1.00005 MULES: Correcting alpha.water Phase-1 volume fraction = 0.526704 Min(alpha.water) = -6.6909e-006 Max(alpha.water) = 1.00005 GAMG: Solving for p_rgh, Initial residual = 0.000985976, Final residual = 3.58749e-006, No Iterations 2 time step continuity errors : sum local = 0.000155897, global = -1.81303e-005, cumulative = 0.0188479 GAMG: Solving for p_rgh, Initial residual = 4.06798e-006, Final residual = 4.36954e-009, No Iterations 5 time step continuity errors : sum local = 1.90033e-007, global = -2.26087e-008, cumulative = 0.0188479 smoothSolver: Solving for omega, Initial residual = 0.00272371, Final residual = 8.55104e-006, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.00272037, Final residual = 1.86617e-005, No Iterations 1 bounding k, min: 2.00531e-050 max: 0.482268 average: 0.0258735 ExecutionTime = 165.104 s ClockTime = 165 s Courant Number mean: 0.0280023 max: 0.490249 Interface Courant Number mean: 0.00543041 max: 0.490249 deltaT = 0.0129638 Time = 10.4426 PIMPLE: iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 0.00117333, Final residual = 8.48255e-009, No Iterations 2 Phase-1 volume fraction = 0.526855 Min(alpha.water) = -4.85513e-014 Max(alpha.water) = 1.00005 MULES: Correcting alpha.water Phase-1 volume fraction = 0.526855 Min(alpha.water) = -1.04195e-005 Max(alpha.water) = 1.00005 GAMG: Solving for p_rgh, Initial residual = 0.000973585, Final residual = 3.56581e-006, No Iterations 2 time step continuity errors : sum local = 0.000155211, global = -1.80933e-005, cumulative = 0.0188298 GAMG: Solving for p_rgh, Initial residual = 4.04344e-006, Final residual = 4.37612e-009, No Iterations 5 time step continuity errors : sum local = 1.90631e-007, global = -2.39185e-008, cumulative = 0.0188298 smoothSolver: Solving for omega, Initial residual = 0.00270286, Final residual = 8.40975e-006, No Iterations 1 bounding omega, min: 4.02301e-022 max: 55.1144 average: 7.09461 smoothSolver: Solving for k, Initial residual = 0.00269784, Final residual = 1.84009e-005, No Iterations 1 bounding k, min: 0 max: 0.481787 average: 0.0257665 ExecutionTime = 165.198 s ClockTime = 165 s Courant Number mean: 0.0279477 max: 0.491727 Interface Courant Number mean: 0.00540864 max: 0.491727 deltaT = 0.0129638 Time = 10.4555 PIMPLE: iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 0.00116406, Final residual = 8.23924e-009, No Iterations 2 Phase-1 volume fraction = 0.527005 Min(alpha.water) = -3.16047e-013 Max(alpha.water) = 1.00005 MULES: Correcting alpha.water Phase-1 volume fraction = 0.527005 Min(alpha.water) = -1.57994e-005 Max(alpha.water) = 1.00005 GAMG: Solving for p_rgh, Initial residual = 0.000965437, Final residual = 3.54831e-006, No Iterations 2 time step continuity errors : sum local = 0.000154608, global = -1.83531e-005, cumulative = 0.0188115 GAMG: Solving for p_rgh, Initial residual = 4.03026e-006, Final residual = 4.37963e-009, No Iterations 5 time step continuity errors : sum local = 1.90979e-007, global = -2.52896e-008, cumulative = 0.0188114 smoothSolver: Solving for omega, Initial residual = 0.0026907, Final residual = 8.3251e-006, No Iterations 1 bounding omega, min: 0 max: 56.1998 average: 7.0808 smoothSolver: Solving for k, Initial residual = 0.00270496, Final residual = 1.83078e-005, No Iterations 1 bounding k, min: 2.00873e-050 max: 0.481382 average: 0.0256621 ExecutionTime = 165.292 s ClockTime = 165 s Courant Number mean: 0.0279038 max: 0.493424 Interface Courant Number mean: 0.00542181 max: 0.493424 deltaT = 0.0129638 Time = 10.4685 PIMPLE: iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 0.00115527, Final residual = 7.95274e-009, No Iterations 2 Phase-1 volume fraction = 0.527155 Min(alpha.water) = -1.26483e-014 Max(alpha.water) = 1.00005 MULES: Correcting alpha.water Phase-1 volume fraction = 0.527155 Min(alpha.water) = -2.35671e-005 Max(alpha.water) = 1.00005 GAMG: Solving for p_rgh, Initial residual = 0.000957572, Final residual = 3.52308e-006, No Iterations 2 time step continuity errors : sum local = 0.00015364, global = -1.92597e-005, cumulative = 0.0187922 GAMG: Solving for p_rgh, Initial residual = 4.01204e-006, Final residual = 4.35063e-009, No Iterations 5 time step continuity errors : sum local = 1.89872e-007, global = -2.79846e-008, cumulative = 0.0187921 job aborted: [ranks] message [0] terminated [1] process exited without calling finalize [2-3] terminated ---- error analysis ----- [1] on DESKTOP-Q8AJK77 interfoam ended prematurely and may have crashed. exit code 3 ---- error analysis ----- Thanks Regards. |
Nguyen Duy Trong
Rep Power: 12 ![]() |
As I see, you are using openFoam for windows from blueCFD. I think that is quite old and unstable version. Why don't you use a newer version with linux platform
So what is the newer version and you want me to use linux?
Nguyen Duy Trong
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
