Modify SemiImplicitSource for time varying source
Old   August 20, 2020, 11:21
Default Modify SemiImplicitSource for time varying source
Sagar
ksgr is on a distinguished road
Hello all!
I am trying to model a time varying mass source with reactingParcelFoam solver. I basically want to see what happens when the compactness of the source changes to the evolution of the species. For this I have removed the source which is computed from the evaporation of the parcels in the OpenFoam. I am trying to use fvOptions to multiply the source with sinusoid to make it vary in the time domain.
To add sin function, I am trying to add the sin(Time) to Su in the source file. I copied the SemiImplicitSource source files to my local working directory and then changed the file names to sineSource.C and sineSource.H and made changes accordingly everywhere including the Make folder. However, when I try to compile I get the following error
sources/general/sineSource/sineSource.C:38:18: error: redefinition of ‘const wordList Foam::fv::sineSource<Type>::volumeModeTypeNames_’
     IStringStream("(absolute specific)")()
In file included from sources/general/sineSource/sineSource.H:221:0,
                 from sources/general/sineSource/sineSource.C:27:
sources/general/sineSource/sineSource.C:36:22: note: ‘const wordList Foam::fv::sineSource<Type>::volumeModeTypeNames_’ previously declared here
 const Foam::wordList Foam::fv::sineSource<Type>::volumeModeTypeNames_
sources/general/sineSource/sineSource.C:46:1: error: redefinition of ‘Foam::fv::sineSource<Type>::volumeModeType Foam::fv::sineSource<Type>::wordToVolumeModeType(const Foam::word&) const’
sources/general/sineSource/sineSource.C:46:1: note: ‘Foam::fv::sineSource<Type>::volumeModeType Foam::fv::sineSource<Type>::wordToVolumeModeType(const Foam::word&) const’ previously declared here
sources/general/sineSource/sineSource.C:69:12: error: redefinition of ‘Foam::word Foam::fv::sineSource<Type>::volumeModeTypeToWord(const Foam::fv::sineSource<Type>::volumeModeType&) const’
sources/general/sineSource/sineSource.C:69:12: note: ‘Foam::word Foam::fv::sineSource<Type>::volumeModeTypeToWord(const Foam::fv::sineSource<Type>::volumeModeType&) const’ previously declared here
sources/general/sineSource/sineSource.C:86:6: error: redefinition of ‘void Foam::fv::sineSource<Type>::setFieldData(const Foam::dictionary&)’
 void Foam::fv::sineSource<Type>::setFieldData(const dictionary& dict)
sources/general/sineSource/sineSource.C:86:6: note: ‘void Foam::fv::sineSource<Type>::setFieldData(const Foam::dictionary&)’ previously declared here
sources/general/sineSource/sineSource.C:112:1: error: redefinition of ‘Foam::fv::sineSource<Type>::sineSource(const Foam::word&, const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)’
sources/general/sineSource/sineSource.C:112:1: note: ‘Foam::fv::sineSource<Type>::sineSource(const Foam::word&, const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)’ previously declared here
sources/general/sineSource/sineSource.C:132:6: error: redefinition of ‘void Foam::fv::sineSource<Type>::addSup(Foam::fvMatrix<Type>&, Foam::label)’
sources/general/sineSource/sineSource.C:132:6: note: ‘virtual void Foam::fv::sineSource<Type>::addSup(Foam::fvMatrix<Type>&, Foam::label)’ previously declared here
sources/general/sineSource/sineSource.C:195:6: error: redefinition of ‘void Foam::fv::sineSource<Type>::addSup(const volScalarField&, Foam::fvMatrix<Type>&, Foam::label)’
sources/general/sineSource/sineSource.C:195:6: note: ‘virtual void Foam::fv::sineSource<Type>::addSup(const volScalarField&, Foam::fvMatrix<Type>&, Foam::label)’ previously declared here
/home/sagar/OpenFOAM/OpenFOAM-4.x/wmake/rules/General/transform:8: recipe for target 'Make/linux64GccDPInt32Opt/sources/general/sineSource/sineSource.o' failed
make: *** [Make/linux64GccDPInt32Opt/sources/general/sineSource/sineSource.o] Error 1
I think that with the new sineSource type it is still referencing to the semiImplicitSource by the redefinition error. I am not so sure of it. I don't know whether any other changes needs to be made as this is a general source. Any help would be appreciated
Thank you
ksgr is offline   Reply With Quote
fvoptions mass source
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
