DeltaT dependency of solution in chtMultiRegionSimpleFoam
Old   August 18, 2020, 09:29
Default DeltaT dependency of solution in chtMultiRegionSimpleFoam
aat74 is on a distinguished road
Hello Everybody,
I've a case: a room filled with air, adiabatic round & bottom walls and free atmosphere on top (p_rgh as totalPressure and U as pressureInletOutletVelocity). in the middle of the room is a solid that represents a constant heat source(fvoption asscalarSemiImplicitSource).
Ignoring the cooling with convection the solid temperature should rise up 6 degree celsius in 1 sec (1 unit of time).
When I run chtMultiRegionsSimpleFoam for 1 time unit with different DeltaT I get different temperature for solid. I tries from 0.5-0.001.
The smaller is the time step the higher is the end Temperature after 1 time unit, and it differs very much.
I doub't that I have problem with interpretation of entTime and deltaT.
do they have absolute meanings(like 1 means 1 sec and 0.001 means 1 msec) or they are relative(endTime is interpreted according to DeltaT).
Thank you in advance for your advice(s).
All the best
Amirali
aat74 is offline   Reply With Quote
Old   August 18, 2020, 14:15
wanghongjie
wanghongjie is on a distinguished road
I initially coupled cht and interPhaseChangeFoam together, but there are problems that I can't solve. Please help me to see if there is a solution. I have declared these parameters in createFluidFields.H, but after compilation, it shows that these parameters in setRegionFluidFields.H are not declared. I am not very clear about that. Thanks!
./fluid/setRegionFluidFields.H:15:25: error: ‘UFluid’ was not declared in this scope 15 | volVectorField& U = UFluid[i]; | ^~~~~~ ./fluid/setRegionFluidFields.H:16:31: error: ‘phiFluid’ was not declared in this scope 16 | surfaceScalarField& phi = phiFluid[i]; | ^~~~~~~~ ./fluid/setRegionFluidFields.H:17:27: error: ‘rhoFluid’ was not declared in this scope 17 | volScalarField& rho = rhoFluid[i]; | ^~~~~~~~ ./fluid/setRegionFluidFields.H:18:36: error: ‘interfaceFluid’ was not declared in this scope; did you mean ‘interface’? 18 | interfaceProperties& interface=interfaceFluid[i]; | ^~~~~~~~~~~~~~ | interface ./fluid/setRegionFluidFields.H:19:32: error: ‘rhoPhiFluid’ was not declared in this scope 19 | surfaceScalarField& rhoPhi=rhoPhiFluid[i];
and others
(I am very sorry that I can not upload pictures to the web page, which will cause reading inconvenience. I can only paste part of the wrong text.)
wanghongjie is offline   Reply With Quote
chtmultiregionsimpefoam, deltat
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
