August 18, 2020, 04:35 |
Backtrace error - elements not defined
Rep Power: 6 |
Hi everyone,
I'm trying to run a simulation of a coal fired burner. As basis I use the tutorial coalChemistryFoam, which I changed accordingly. Under constant/foam.inp I recorded several reactions. If I try to start the simulation I get a backtrace with the hint: "Elements not defined in ..../constant/foam.inp". Thereupon I tried to define elements accordingly but that did not work either. The error message is attached. Why can't I get it to run? Can someone help me? |
User defined memory value changing | minhoabc | FLUENT | 2 | June 22, 2017 06:28 |
Not defined orientation change while running SU2_CFD | mdawson25 | SU2 | 4 | May 11, 2017 09:52 |
why CPtr_ defined as SlicedGeometricField, whereas magSfPtr_ as GeometricField? | Jerryfan | OpenFOAM Programming & Development | 1 | July 6, 2016 21:02 |
fetal overflow in user defined cavitation model | unclewallcn | CFX | 15 | January 20, 2016 22:17 |
OpenFOAM13 for Mac OSX Darwin 104 | hjasak | OpenFOAM Installation | 70 | September 24, 2010 05:06 |
