August 16, 2020, 09:28 |
Foam fatal io error
SEYEDSINARAZAVI
Hello everyone
I want solve a 2D wavemakerFlum with olaDyMFlow after blockMesh and decomposepar and setField and mpirun -np 4 olaDyMFlow -parallel say this Error How Fixed thise Error? Cannot open include file "/home/hydro/run/wavemakerFlume/constant/wavemakerMovement.txt" while reading dictionary "/home/hydro/run/wavemakerFlume/constant/wavemakerMovementDict" [0] [0] file: /home/hydro/run/wavemakerFlume/constant/wavemakerMovementDict at line 21. [0] [0] From function static bool Foam::functionEntries::includeEntry::execute(Foam: :dictionary&, Foam::Istream&) [0] in file db/dictionary/functionEntries/includeEntry/includeEntry.C at line 170. [0] FOAM parallel run exiting [0] Last edited by S.SINA; August 17, 2020 at 03:50. |
October 13, 2020, 16:54 |
Grivalszki Péter
Rep Power: 7 |
Hi! I have the same problem. Do you have any solution since your post?
October 14, 2020, 05:10 |
Rep Power: 9 |
A guess: Maybe .txt at the end of the file is the problem?
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 10:40 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 06:34 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 13:34 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
