Conjugate heat transfer + Periodic Boundaries |
August 15, 2020, 10:17 |
Sai Guruprasad Jakkala
Rep Power: 9 |
I am trying to do a conjugate heat transfer simulation with periodic boundary conditions in the x & y directions. I am using cyclicAMI boundary condition because the periodic faces are not conformal.
I am using meanVelocityForce from fvOptions to drive the flow. The simulation runs but the velocity starts decreasing every iteration and eventually reaches a very low value (order of 10^-12). I did some digging around and found that the meanVelocityFore can be used only for incompressible flows, but over in this place it says it can be added to compressible momentum equation also. I would like to know if I can use meanVelocityForce along with chtMultiRegionFoam or chtMultiRegionSimpleFoam. If I can not use it, is there any other way I can direct the flow for periodic boundary conditions in the x & y directions. |
chtmultiregionfoam, conjugate heat transfer, openfoam 1906, periodic bc, periodic heat transfer |
Current state of conjugate heat transfer in OpenFOAM | Dreoasteh | OpenFOAM | 2 | April 4, 2023 13:47 |
Thermal non-equilibrium porous media model with conjugate heat transfer | Hexahedron | FLUENT | 9 | February 22, 2023 02:55 |
Add conjugate heat transfer between solid/liquid to buoyantBoussinesqPimpleFoam | onlyacan | OpenFOAM Programming & Development | 3 | March 13, 2019 11:16 |
Interphase mass transfer of a reaction | cfx_ws1992 | Main CFD Forum | 0 | May 15, 2017 21:42 |
VOF with conjugate heat transfer | vs138 | Fluent Multiphase | 1 | November 12, 2014 08:52 |
