Getting low cl for wing in pimpleFoam and oscillating cl in simpleFoam |
August 15, 2020, 04:48 |
TWB
Rep Power: 19 |
I'm trying to simulate a 3d wing. The mesh is created using snappyHexMesh and they seem ok in Paraview. I used pimplefoam and simplefoam with komegaSST to get the cl, cd etc. However, the ans I get I seems lower than expected. From the simulation, the cl increase from 0.08 to 0.2 (AOA ~ 18) and then drops.The actual model weighs about 6.7kg and at AOA ~ 18, cl = 0.2 corresponds to a lift force of 40N, which is not enough to support the weight. This ans is from pimplefoam. I also tried simplefoam but I got oscillating ans ranging between +/- 0.2 I tried to increase resolution but the result is similar. I tried to change to KE turbulence model but also small difference. Any suggestion? anything else I should try? |
pimpleFoam - Flow across an oscillating cylinder simulation crashing | iceman53y | OpenFOAM Running, Solving & CFD | 2 | November 27, 2019 06:13 |
PimpleFoam - oscillating forces and drag coefficient | crizpi21 | OpenFOAM Running, Solving & CFD | 3 | July 2, 2018 12:53 |
