Overset CellTypes not updated correctly
Old   August 14, 2020, 22:28
Default Overset CellTypes not updated correctly
Michael@UW is on a distinguished road
I use overPimpleDyMFoam in OpenFOAM v2006 to simulate the oscillating rotation of two valves.
The cellTypes of some cells are not switched back to 'calculated' but keep 'hole' after the valves leave these cells (see figure attached). It seems the 'cellTypes' are updated correctly during the open process but the issue occurs during the close process.
I use adjustableRunTime and adjustTimeStep to gurantee maxCo to be smaller than 2.0.
I also attached the dictionary files. Hope someone can help me figure out how to solve the problem.
Thanks in advance!
Michael
controlDict
application     overPimpleDyMFoam;
startFrom		latestTime;
deltaT          0.0001028;
startTime		0;
endTime		0.073502;
writeControl    adjustableRunTime;
writeInterval   0.0001028;
purgeWrite      0;
writeFormat     binary;
writePrecision  10;
writeCompression off;
timeFormat      general;
timePrecision   10;
runTimeModifiable yes;
adjustTimeStep	yes;
maxCo 2.0;
maxDeltaT 0.0001028;
fvSchemes
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss upwind;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
    laplacian(diffusivity,cellDisplacement)  Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
oversetInterpolation
    method          cellVolumeWeight;
fluxRequired
    default         no;
    pcorr           ;
    p               ;
oversetInterpolationSuppressed
    grad(p);
    surfaceIntegrate(phiHbyA);
	//cellMotionU;
	//pointMotionU;
fvSolution
solvers
    "(cellMotionU|cellDisplacement.*)"
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-9;
        relTol          0;
    p
        solver          PBiCGStab;
        preconditioner  DILU;
        tolerance       1e-11;
        relTol          0.01;
    pFinal
        $p;
        relTol          0;
    pcorr
        $p;
        solver          PCG;
        preconditioner  DIC;
    pcorrFinal
        $pcorr;
        relTol          0;
    "(U|k|epsilon)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-6;
        relTol          0;
    "(U|k|epsilon)Final"
        $U;
        tolerance       1e-6;
        relTol          0;
PIMPLE
    momentumPredictor   false;
    correctPhi          false;
    nOuterCorrectors    1;
    nCorrectors         3;
    nNonOrthogonalCorrectors 1;
    residualControl
        U
                tolerance  1e-5;
                relTol      0;
        p
                tolerance  5e-4;
                relTol      0;
    ddtCorr             true;
    pRefPoint           (-0.000372638 -0.00338073 0);
    pRefValue           0.0;
	checkMeshCourantNo 		yes;
	moveMeshOuterCorrectors true;
relaxationFactors
    fields
        p      0.3;
        pFinal   1;
    equations
        "U|k|epsilon"     0.3;
        "(U|k|epsilon)Final"   1;
Michael@UW is offline   Reply With Quote
2DOF Planning hull resistance study with overset CFD_fan OpenFOAM Running, Solving & CFD 7 July 13, 2021 06:03
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca insane OpenFOAM Running, Solving & CFD 0 May 17, 2020 23:35
Overset Mesh error : no startcell found ! Cris ZC STAR-CCM+ 4 September 9, 2019 11:43
Help in setting up an overset mesh RKE STAR-CCM+ 1 February 21, 2014 22:35
Overset MESH problem DFBI 6DOF Ale85 STAR-CCM+ 0 October 1, 2013 13:25
