Errors when using different ddt schemes in interFoam
Old   August 11, 2020, 03:12
Default Errors when using different ddt schemes in interFoam
abdikerim kurbanaliev
kerim is on a distinguished road
Dear Foamers,
In order to validate interFoam solver I have changed ddt schemes to from Euler to Euler1. As it is expected I got an error – unknown ddt scheme Euler1. At the same time, I have 8 valid ddt schemes.
Than the using CoEuler, CrankNicolson, SLTS schemes give me an error like attempt to read beyond EOF. It happens despite the fact that it is semicolon at the end of this row.
The backward scheme gives an error – only Euler and CrankNicolson ddt are supported.
When I used bounded scheme an error was like Ddt scheme not specified.
I used openFoam7 installed on Ubuntu 18.04.4 LTS.
By the way the same situation with the OpenFoam6 installed on Ubuntu 16.04.4 LTS
Would like someone help me to clarify this issue?
Any kind of help is highly appreciated.
Please see the attechments for more information.
Kerim
kerim is offline   Reply With Quote
Old   August 12, 2020, 16:55
Santiago Lopez Castano
Santiago is on a distinguished road
Originally Posted by kerim View Post
Dear Foamers,
Kerim
CoEuler and SLTS need more entries: either the flux or density, and the maximum Co number. Check the implementation for details'
CrankNicolson needs the weight between explicit/implicit discretization. setting 0 is fully implicit, and 1 fully explicit.
Santiago is offline   Reply With Quote
Old   August 15, 2020, 00:14
Thank you very much.
Kerim
How to use PIMPLE properly? floquation OpenFOAM Running, Solving & CFD 27 August 12, 2024 11:15
interFoam wave propagation and explosion of Courant number and residuals ChiaraViola OpenFOAM Running, Solving & CFD 1 June 26, 2019 06:36
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
