Looking for example for heater rods submerged in the pool |
sw choi
Rep Power: 6 ![]() |
Dear All,
Sorry for readers. I repeat the same question ; next thread. Please ignore (2) question. (1) I am in the middle of developing the two heater rods submerged in the pool based on the tutorials;solidQuenching2D (example in the chtMultiRegionTwoPhaseEulerFoam). When I try to duplicate heater by copying the dimensions/thermal properties of existing one, I have a following errors: --> FOAM FATAL ERROR: {Cannot find file "points" in directory "water/polyMesh" in times "0" down to constant } This error message seems to be caused by my input error for heater cell zone in topoSetDict; I have also changed many parameters associated with newly added heater rod in input. Whatever I change, I got the same error message. I wonder if I can get any modified example including two heaters from solidQuenching2D tutorial or give me a comments from my working file(please see the attached file). 2) Please answer my comment question (see below //). { name bottomWaterCellSet; type cellSet; action new; source cellToCell; sourceInfo { set heater2CellSet; } } { name bottomWaterCellSet; type cellSet; action invert; // I don't understand what this card means } As an openFoam beginner , it would be great helpful for me to get any comment from you OpenFOAM expert. Thanks in advance. Best wishes, Sung Last edited by choist31; August 11, 2020 at 11:42. Reason: repeat of next posting memo |
boiling modeling, heater rods |
Free turbulent water jet into liquid metal pool, inlet submerged | Estone | Fluent Multiphase | 1 | February 22, 2019 13:39 |
HELP!: swimming pool flow problem | Tee | FLUENT | 1 | September 8, 2005 08:29 |
HELP!:CFD modelling using FLUENT in swimming pool | Tee | Main CFD Forum | 0 | September 7, 2005 20:48 |
Radiation between heated rods | lego | Main CFD Forum | 1 | November 13, 2003 08:39 |
Radiation between heated rods | lego | CFX | 0 | November 12, 2003 08:44 |
