Philipp
Rep Power: 7 ![]() |
Hi everyone, I am developing a programm code to simulate the evaporation of liquid nitrogen overflowing/impinging a hot surface.
My first step is just to simulate a multiphase flow without the evaporation process. The flow inlet is on the left side. Attached you can find a file with the set boundary conditions. I think it should not be a problem to simulate that case, because nothing spectacular happens. However, the problem is that I get some "artefacts" flowing from the outlet to my calculation domain. I think the problem can be solved by fixing the boundary conditions. Does anyone of you know what I should change or what is the problem? Big thanks! |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 05:58 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
