fixedFluxPressure BC: updateCoeffs(const scalarField& snGradp) MUST be called ... |
August 5, 2020, 09:52 |
Mohammad Khojastehmehr
Rep Power: 6 |
Hey everybody!
I want to simulate 1D steady state flow in porous media using Darcy law. The equations are as follows: where U is the velocity, p is pressure. is the viscosity and K is the permeability. As the inlet velocity is considered a constant in the case of my problem, I decided to use fixedFluxPressure BC. So, the the initial and boundary conditions would be: p: Code:
internalField uniform 0; boundaryField { inlet { type fixedFluxPressure; } outlet { type fixedValue; value uniform 0; } frontAndBackAndTopAndBottom { type empty; } } Code:
boundaryField { inlet { type fixedValue; value uniform (1 0 0); } outlet { type zeroGradient } frontAndBackAndTopAndBottom { type empty; } } Code:
fvScalarMatrix pEqn ( fvm::laplacian(k/mu,p) ); pEqn.solve(); U=-k/mu*fvc::grad(p); Code:
--> FOAM FATAL ERROR: updateCoeffs(const scalarField& snGradp) MUST be called before updateCoeffs() or evaluate() to set the boundary gradient. From function virtual void Foam::fixedFluxPressureFvPatchScalarField::updateCoeffs() in file fields/fvPatchFields/derived/fixedFluxPressure/fixedFluxPressureFvPatchScalarField.C at line 157. |
June 25, 2021, 07:03 |
Kennedy Murithi Micheni
Rep Power: 6 |
boundary condition, darcy's law, fixedfluxpressure |
updateCoeffs(const scalarField& snGradp) MUST be called before updateCoeffs() | jinyaqing | OpenFOAM Running, Solving & CFD | 7 | March 14, 2024 12:57 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 05:37 |
fixedFluxPressure with PisoFoam | me.ouda | OpenFOAM Running, Solving & CFD | 1 | October 27, 2015 06:30 |
terminate called after throwing an instance of 'int' | b614910 | SU2 | 10 | July 27, 2014 23:16 |
reconstructParMesh not working with an axisymetric case | francesco | OpenFOAM Bugs | 4 | May 8, 2009 06:49 |
