blockMesh ERROR
Old   August 5, 2020, 07:48
Thumbs down blockMesh ERROR
Alessio
Alex_619 is on a distinguished road
hello everyone,
I have just installed OpenFOAM on my laptor running UBUNTU 20.04, I have tried to run a tutorial as a test, to see if everything is working but once I selected the ShockTube folder that I have previously copied on my desktop, I tried to generate a mesh using the command 'blockMesh' but it returns the following error:
FOAM FATAL ERROR :
Could not find mandatory etc entry (mode=ugo)
'controlDict'
I have checked and the controlDict file is in the right folder "system".
Does someone have a solution?
Thank you.
Alessio
Alex_619 is offline   Reply With Quote
Old   August 5, 2020, 19:09
Claudio Boezio
Ship Designer is on a distinguished road
Hi Alessio,
make sure that the file header of controlDict is properly set up like this:
FoamFile {
   version  2.0;
    format  ascii;
     class  dictionary;
    object  controlDict;
  location  "system";
A wrong class may make OpenFOAM give an error message that the file is not found, although it may very well exist and has the correct file name. The correct filename alone isn't sufficient. The file header needs to be correct too. Hope this helps.
Do other tutorial cases work properly?
Ship Designer is offline   Reply With Quote
Old   April 21, 2022, 13:43
HY
yhhit is on a distinguished road
Hi, Probably something wrong with your .bashrc file.
source home/username/OpenFOAM/OpenFOAM-v2012/etc/bashrc.
Originally Posted by Alex_619 View Post
hello everyone,
FOAM FATAL ERROR :
'controlDict'
Thank you.
Alessio
yhhit is offline   Reply With Quote
blockmesh, controldict, running first simulation
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
