August 4, 2020, 03:09 |
buoyantSimpleFoam simulation collapse
Pierrick LE DONNE
Hello everyone,
I'm trying to simulate the interaction of a jet (secondary flow) in a turbulent mainstream flow using the buoyantSimpleFoam solver. The hot turbulent freestream (air at T=540K) is flowing over a flat plate (wall) and the cold secondary flow (air at T=300K) is injected verticaly from a plenium then a pipe (both walls) inclined at 35° compared to the plate (picture of the domain given in the file attached). I've been able to run the simpleFoam solver on this domain, however i would like now to simulate the adiabatic temperature over the plate (with buoyantSimpleFoam), but I don't know how to set up the pressure/p_rgh initial conditions (for the others 0 files I took it from my simpleFoam simulation), and my simulation collapses after 6 or 7 iterations (it crashes at the p_rgh calculation step). From what I've read from the OpenFoam tutos, so far I've tried to set the pressure with the "calculated" BC for all boundaries, and for my p_rgh initial BC i've put "fixedFluxPressure" (with zero gradient and 1atm value) for the walls and the two inlets, and a fixed value at the outlet (1atm as well). My p and p_rgh 0 files are given below ($pressure is 101325): Code:
FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; #include "include/initialConditions" internalField uniform $pressure; boundaryField { Blade { type calculated; value uniform $pressure; } Pipe { type calculated; value uniform $pressure; } CoolantInlet { type calculated; value uniform $pressure; } Plenium { type calculated; value uniform $pressure; } Inlet { type calculated; value uniform $pressure; } Outlet { type fixedValue; value uniform $pressure; } TopBoundary { type slip; } FrontAndBack { type symmetry; } } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Code:
FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; #include "include/initialConditions" internalField uniform $pressure; boundaryField { Blade { type fixedFluxPressure; gradient uniform 0; value uniform $pressure; } Pipe { type fixedFluxPressure; gradient uniform 0; value uniform $pressure; } CoolantInlet { type fixedFluxPressure; gradient uniform 0; value uniform $pressure; } Plenium { type fixedFluxPressure; gradient uniform 0; value uniform $pressure; } Inlet { type fixedFluxPressure; gradient uniform 0; value uniform $pressure; } Outlet { type fixedValue; value uniform $pressure; } TopBoundary { type slip; } FrontAndBack { type symmetry; } } // ************************************************************************* // Thank you |
buoyantsimplefoam, pressure field bc |
Bubble Collapse Simulation in STAR-CCM+ | JM27 | STAR-CCM+ | 3 | January 2, 2023 05:21 |
Convergence Problem - Transient Simulation | gemxx | Main CFD Forum | 0 | July 15, 2018 09:36 |
Mapping Field Data for Mesh Regions from Another Simulation | veterator | OpenFOAM Pre-Processing | 1 | July 10, 2018 05:28 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 02:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 15:06 |
