I write my data every 5 time steps using overPimpleDyMFoam (OpenFOAM v2006).
writeControl timeStep; writeInterval 5; What is p_normalisation for? How to suppress its output? |
I found the reason. Because I switched on the Debug option in controlDict file. So the filed is written out at every time step according to the code below:
if (debug) { Pout<< "dynamicOversetFvMesh::solve() :" << " writing matrix normalisation for field " << m.psi().name() << " to " << scale.name() << endl; } from https://www.openfoam.com/documentation/guides/latest/api/dynamicOversetFvMeshTemplates_8C_source.html |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
