Accessing the first surface center near the boundary
Old   July 31, 2020, 12:51
Default Accessing the first surface center near the boundary
Yujuan Luo
Yujuan is on a distinguished road
Hi all,
I know that .patchInternalField() can be used to access the first cell center near the boundary. Now I want to access the first surface center near the boundary (the surface center which is in symmetry with the boundary point regarding to the first cell center near the boundary), is there any functions like patchInternalField, or what else should I do?
Yujuan is offline   Reply With Quote
Old   August 4, 2020, 10:37
Wenyuan Fan
Wenyuan is on a distinguished road
Hi Yujuan,
I don't think such a built-in function exists. Since "the first surface" is simply not defined in a general polyhedral framework like OpenFOAM. For instance, how do you define the first surface of a tetrahedron adjacent to a patch?
According to your description, you are dealing with some special types of cells. In this case, you need to write your own code to find that surface, which is not difficult.
Wenyuan is offline   Reply With Quote
Old   August 14, 2020, 11:31
Yujuan Luo
Originally Posted by Wenyuan View Post
Hi Yujuan,
Hi Wenyuan,
Thanks a lot for your suggestions. I'll have a try.
Old   August 14, 2020, 11:40
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
I would suggest looping through the cells returned by patchInternalField and then writing code to test each of the faces of those cells according to your criterion (which seems quite specialized to a particular application).
Chris DeGroot, PhD, PEng
CEO, Maple Key Labs
www.maplekeylabs.com
cdegroot is offline   Reply With Quote
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
domain imbalance for enrgy equation happy CFX 14 September 6, 2012 02:54
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
