Instabilites with flux limiters rhoCentralFoam |
Rep Power: 7 ![]() |
I have currently modelling a hypersonic free stream. I have issues using flux limiters. Whenever I use sth. besides upwind, the simulation crashes: Code:
at ??:? [276] #1 Foam::sigFpe::sigHandler(int) at ??:? [276] #2 ? in "/lib64/libc.so.6" [276] #3 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:? [276] #4 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:? [276] #5 ? at ??:? [276] #6 __libc_start_main in "/lib64/libc.so.6" [276] #7 ? at ??:? [bcn1602:16130] *** Process received signal *** [bcn1602:16130] Signal: Floating point exception (8) [bcn1602:16130] Signal code: (-6) [bcn1602:16130] Failing at address: 0x769600003f02 [bcn1602:16130] [ 0] /lib64/libc.so.6(+0x36400)[0x2aaaafe06400] [bcn1602:16130] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x2aaaafe06387] [bcn1602:16130] [ 2] /lib64/libc.so.6(+0x36400)[0x2aaaafe06400] [bcn1602:16130] [ 3] /sw/eng/OpenFOAM/4/skl/gcc/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE9calculateEv+0x2c1)[0x2aaaaccfeb01] [bcn1602:16130] [ 4] /sw/eng/OpenFOAM/4/skl/gcc/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE7correctEv+0x2a)[0x2aaaacd2186a] [bcn1602:16130] [ 5] rhoCentralFoam[0x43328e] [bcn1602:16130] [ 6] /lib64/libc.so.6(__libc_start_main+0xf5)[0x2aaaafdf2555] [bcn1602:16130] [ 7] rhoCentralFoam[0x435aba] [bcn1602:16130] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun noticed that process rank 276 with PID 16130 on node bcn1602 exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- Here are my schemes and solution dicts: Code:
fluxScheme Kurganov; ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default Gauss linear div(tauMC) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; reconstruct(rho) vanAlbada; reconstruct(U) vanAlbadaV; reconstruct(T) vanAlbada; } snGradSchemes { default corrected; } Code:
solvers { "rho.*" { solver diagonal; } "U.*" { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-9; relTol 0.0; } e { $U; tolerance 1e-10; relTol 0.0; } } Any suggestions? Kind regards, shock77 |
The residuals are very small (order of 1e-15) and I also varried the mesh resolution from 1 mm to 0.2 mm and it had no effect.
the normal residuals you get while computing. |
Possibly you gain more information by looking into the spatial distribution of the residual using
1.1/ In system-folder/controlDict-file … writeInterval 10; … functions { #includeFunc residualFieldDict } 1.2/ In system-folder/residualFieldDict-file type solverInfo; // specific for version-1906 libs ("libutilityFunctionObjects.so"); writeControl runTime; // timeStep; writeInterval 10; // make sure this to be equal as the writeInterval specified in the controlDict file writeResidualFields yes; |
I think I have those instabilites because of the strong expansion of the gas. The simulation crashes while solving the energy equation, although in the previous timestep the residuals are ok. So I think the solution is to optimize the schemes. I am trying this now as stable solution: Code:
fluxScheme Kurganov; ddtSchemes { default Euler; } gradSchemes { default faceLimited Gauss linear 1; } divSchemes { default none; div(tauMC) Gauss linear; div(phi,U) Gauss linearUpwindV grad(U); } laplacianSchemes { default Gauss linear uncorrected; } interpolationSchemes { default linear; reconstruct(rho) Minmod; reconstruct(U) MinmodV; reconstruct(T) Minmod; } snGradSchemes { default uncorrected; } wallDist { method meshWave; } |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Central Upwind Flux (rhoCentralFoam) in Implicit LUSGS Solver | ChrisA | OpenFOAM Programming & Development | 7 | April 23, 2019 05:10 |
Doubt regarding MUSCL scheme implementation and associated limiters | SangeethCFD | Main CFD Forum | 0 | October 7, 2017 09:00 |
CFL dependent flux limiters in OpenFOAM | jimteb | OpenFOAM Programming & Development | 0 | January 2, 2017 09:00 |
Udf for moving heat flux in 2D cylindrical geometry | devia21 | Fluent UDF and Scheme Programming | 0 | April 20, 2015 00:27 |
