July 30, 2020, 12:36 |
Multiple instances of fieldAverage
Andrew
Rep Power: 8 |
It is possible to use multiple instances of fieldAverage in controlDict but for the same variable?
What I am trying to achieve is a timeaverage for velocity U over two different periods (i.e., every 0.1 s and much longer over the whole LES simulation 40 s). I seems that openFoam will allow two functions to be included but when I post-process the data in Paraview only one Umean variable is created. Is there some work-around or trick to specify two mean variables based on the same source variable? This is what I'm trying to achieve: Code:
functions { fieldAverage1 { type fieldAverage; functionObjectLibs ("libfieldFunctionObjects.so"); enabled true; writeControl runTime; writeInterval 0.1; fields ( U { mean on; prime2Mean on; base time; } p { mean on; prime2Mean on; base time; } ); } fieldAverage2 { type fieldAverage; functionObjectLibs ("libfieldFunctionObjects.so"); enabled true; writeControl runTime; writeInterval 100; timeStart 60; timeEnd 100; fields ( U { mean on; prime2Mean off; base time; } ); } |
August 4, 2020, 10:58 |
You might have some success by using windows as seen on the online documentation. I just copied from there this part as an example to be filled in. Maybe test an a small case first: Code:
<field name 1> { mean <yes|no>; prime2Mean <yes|no>; base <time|iteration>; windowType exact; window 10.0; windowName <name>; allowRestart true; } Tom |
August 11, 2020, 04:45 |
Andrew
Rep Power: 8 |
Hi Tomf,
Yes that worked out for me. I found I had to specify a windowName but it does work. Thanks. |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs | Pier84 | OpenFOAM Installation | 4 | June 18, 2016 17:22 |
[snappyHexMesh] multiple instances of SnappyHexMesh | mihaipruna | OpenFOAM Meshing & Mesh Conversion | 12 | April 6, 2012 15:59 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 13:21 |
[PyFoam] Running multiple instances of solver using MPI and PyFoam | bfa | OpenFOAM Community Contributions | 3 | January 25, 2011 18:57 |
