constantAlphaContactAngle and cyclicAMI together
Old   July 22, 2020, 14:33
Question constantAlphaContactAngle and cyclicAMI together
Ash Kotwal
Ash Kot is on a distinguished road
Hello Sir/Ma'am,
I am thinking of using cyclicAMI with constantAlphaContactAngle BC together in alpha.water file, is it possible?
Or should I use cyclicACMI?
I know how to set it up for cyclicAMI:
essentially, need to have 'cyclicAMI' defined in 'boundary' file, then defined it as translational or rotational as CFD user's choice, then apply specific parameters as per the translational or rotational definition in 'boundary' file inside polymesh.
But,
Now, in 0 folder, inside 'alpha.fluid','U','p_rgh' files, mention 'cyclicAMI' type for cyclicAMI case, thus my confusion is that is it possible to stack two types together? that is, can apply, type 'cyclicAMI', and type 'constantAlphaContactAngle' for same patch in alpha.fluid file?
Ash Kot is offline   Reply With Quote
alpha.water, constantalphacontactangle, cyclic ami, interfoam
Using createPatch and cyclicAMI in FOAM Extend to create periodicbox manuc OpenFOAM Running, Solving & CFD 1 April 12, 2022 12:36
Getting started with CyclicAMI Algebraist OpenFOAM 4 February 11, 2019 02:39
cyclicAMI - kOmegaSST - divergence issue cyln OpenFOAM Running, Solving & CFD 1 October 5, 2018 11:06
cyclic / cyclicAMI boundary conditon - ICEM Mesh cyln OpenFOAM Running, Solving & CFD 0 November 7, 2017 16:26
Boundary Layer strange result fernexda OpenFOAM Running, Solving & CFD 14 January 15, 2015 08:21
