July 17, 2020, 11:33 |
PimpleFoam using Overset Mesh
Isaac
Rep Power: 13 |
I am a newbie using overset Mesh. I have set up a case using PimpleFoam to run a propeller analysis. Instead of using a proper propeller, I have used a circular disk to rotate, to see if I can get it work. But, for some reason, the analysis uses 1e-17 timestep after a certain time period, when I have checked the mesh in that range, the mesh is getting distorted after certain time. I have included the checkMesh result log file in this thread |
July 17, 2020, 11:36 |
benoit paillard
Rep Power: 16 |
overset should not deform mesh, so there's almost certainly something wrong with your setup, either in dynamicMeshDict or in initial conditions 0. The timestep decrease is due to your simulation crashing (due to your mesh becoming bad), and the adaptative timestep trying to recover from that. |
July 21, 2020, 13:14 |
#3 | |
Isaac
Rep Power: 13 |
I have tried and crosschecked my setup. I have included the dynamicMeshDict in this thread. You are right, not all the elements are rotating, a few elements are being selected as a cellZone when I keep the end time as 1, but when I keep the end time at 0.01, the solve is being successful, where all the elements are being selected. Does the end time have any role in running the solve? Last edited by isaac1326; July 21, 2020 at 13:17. Reason: File Attachments |
oversetmesh, pimpledymfoam, pimplefoam |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 06:02 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
Is overset mesh required? | ahildershavn@yahoo.no | OpenFOAM Running, Solving & CFD | 2 | August 4, 2017 04:23 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
