timeStep is not written !
Old   July 10, 2020, 05:48
Default timeStep is not written !
hbulus is on a distinguished road
Hello everyone,
I want to save case file of last step to continue the analysis in case of a need. You can check my controlDict file:
application     rhoSimpleFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         5000;
deltaT          1;
writeControl    timeStep;
writeInterval   5000;
purgeWrite      0;
writeFormat     ascii;
writePrecision   8;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
graphFormat     raw;
libs
    "libforces.so"
Normally, it was working with this settings but i cant be successful at of1912 with parallel running . Is there anyone who can see the problem in here ?
Thanks a lot!
hbulus is offline   Reply With Quote
Old   July 10, 2020, 07:51
geth03 is on a distinguished road
did you modify anything from the solver code or any other code?
your controlDict looks fine.
geth03 is offline   Reply With Quote
Old   July 10, 2020, 08:23
Yeap the problem is solved. I modified -reconstructPar code with the same name ..
When i fixed the problem is gone. If there are someone who still need this info :
After your parallel run is done, you have to "reconstructPar -latestTime" or "reconstructPar -specifiedTime" .
Suitable timestep for DNS flow cfdnewb123 Main CFD Forum 7 April 16, 2020 15:32
Convergence-behaviour when changing physical timestep in steady-state simulation stud-many ANSYS 0 October 28, 2019 11:30
error with smaller timestep ? Thomas MADELEINE FLUENT 0 August 8, 2016 14:02
Modifying sonicFoam to run with variable timestep - strange results dalaron OpenFOAM Programming & Development 1 September 2, 2013 08:21
Timestep and Pressure Correction Relationship in SIMPLE rks171 Main CFD Forum 23 May 4, 2012 02:04
