Stress Normal to Face
Old   July 7, 2020, 13:08
Default Stress Normal to Face
Christopher Roper
cmroper is on a distinguished road
Hi all,
I am using soliddisplacementfoam to simulate the residual stresses in a plate as a laser passes over it. I have gotten decent results so far, however, my biggest hurdle is a problem I believe with boundary conditions. The plate in the simulation is in the x-y plane with the laser running parallel to the y-axis. If I measure sigma xx parallel to the x-axis (across the laser line) it always goes to 0 at the edges of the plate (see attached photo). I know experimentally and from literature that we should have tension at the laser line and compression at the edges. Can someone help me with this? Currently, my bottom boundary is a fixed value uniform field and all other walls are tractiondisplacement with uniform traction and value of (0 0 0).
link to images: https://imgur.com/a/9vJaOyD
cmroper is offline   Reply With Quote
boundaries condition, laser, openfoam, soliddisplacementfoam, stress
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
