July 7, 2020, 07:07 |
Help debugging error please
Alex
Hello All,
I have been completing the residence time distribution tutorial on the 3 week OpenFOAM course. I have ran into the following error when running the simpleFoam model below. Also, I have attached my initial boundary conditions. I ran a check mesh and all was ok with that, with no errors flagging. I would really appreciate it if anyone could please point me in the right direction. I am new to OpenFoam HTML Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * //Create timeCreate mesh for time = 0SIMPLE: Convergence criteria found p: tolerance 0.01 U: tolerance 0.001 "(k|epsilon|omega|f|v2)": tolerance 0.001Reading field pReading field UReading/calculating face flux field phiSelecting incompressible transport model NewtonianSelecting turbulence model type RASSelecting RAS turbulence model kEpsilonRAS{ RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3;}No MRF models presentNo finite volume options presentStarting time loopstreamLine streamlines: automatic track length specified through number of sub cycles : 5Time = 1smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0296921, No Iterations 1smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0187631, No Iterations 1smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0187631, No Iterations 1GAMG: Solving for p, Initial residual = 1, Final residual = 0.022168, No Iterations 1time step continuity errors : sum local = 3975.52, global = -127.771, cumulative = -127.771smoothSolver: Solving for epsilon, Initial residual = 0.998925, Final residual = 0.0921944, No Iterations 2bounding epsilon, min: -20447.3 max: 139986 average: 2059.25smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0362326, No Iterations 3bounding k, min: -207.63 max: 1282.05 average: 23.699ExecutionTime = 0.15 s ClockTime = 0 sTime = 2smoothSolver: Solving for Ux, Initial residual = 0.44388, Final residual = 0.0295747, No Iterations 1smoothSolver: Solving for Uy, Initial residual = 0.651616, Final residual = 0.0573921, No Iterations 1smoothSolver: Solving for Uz, Initial residual = 0.657235, Final residual = 0.0554798, No Iterations 1GAMG: Solving for p, Initial residual = 0.999977, Final residual = 0.0748386, No Iterations 2time step continuity errors : sum local = 1248.58, global = 89.9923, cumulative = -37.7792smoothSolver: Solving for epsilon, Initial residual = 0.998654, Final residual = 0.0734377, No Iterations 2bounding epsilon, min: -1.10011e+08 max: 7.24544e+08 average: 2.75637e+06smoothSolver: Solving for k, Initial residual = 0.997638, Final residual = 0.0214671, No Iterations 2bounding k, min: -44312.3 max: 3.00798e+06 average: 28120.5ExecutionTime = 0.17 s ClockTime = 0 sTime = 3smoothSolver: Solving for Ux, Initial residual = 0.694117, Final residual = 0.0465392, No Iterations 1smoothSolver: Solving for Uy, Initial residual = 0.909778, Final residual = 0.04456, No Iterations 2smoothSolver: Solving for Uz, Initial residual = 0.917267, Final residual = 0.0730654, No Iterations 1GAMG: Solving for p, Initial residual = 0.0999325, Final residual = 0.00377149, No Iterations 3time step continuity errors : sum local = 470.554, global = -41.2595, cumulative = -79.0387smoothSolver: Solving for epsilon, Initial residual = 0.0514643, Final residual = 1.20315e-18, No Iterations 1bounding epsilon, min: -8.96891e+07 max: 9.12855e+10 average: 3.15238e+08smoothSolver: Solving for k, Initial residual = 0.668235, Final residual = 0.0640498, No Iterations 1bounding k, min: -3.52687e+07 max: 4.23398e+08 average: 1.17979e+06ExecutionTime = 0.19 s ClockTime = 0 sTime = 4smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0581, No Iterations 3smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0747431, No Iterations 4smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0778645, No Iterations 3GAMG: Solving for p, Initial residual = 0.0938442, Final residual = 0.0021085, No Iterations 2time step continuity errors : sum local = 2.59333e+21, global = -2.14381e+19, cumulative = -2.14381e+19smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 0.0423077, No Iterations 2bounding epsilon, min: -2.41386e+29 max: 4.61971e+30 average: 1.53354e+28smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.073478, No Iterations 1bounding k, min: -3.60611e+26 max: 6.70576e+27 average: 1.27874e+25ExecutionTime = 0.22 s ClockTime = 0 sTime = 5smoothSolver: Solving for Ux, Initial residual = 0.409108, Final residual = 0.0246038, No Iterations 2smoothSolver: Solving for Uy, Initial residual = 0.198913, Final residual = 0.0141672, No Iterations 2smoothSolver: Solving for Uz, Initial residual = 0.371958, Final residual = 0.0359996, No Iterations 2GAMG: Solving for p, Initial residual = 1, Final residual = 0.0465964, No Iterations 2time step continuity errors : sum local = 2.60284e+21, global = 1.2003e+20, cumulative = 9.85914e+19smoothSolver: Solving for epsilon, Initial residual = 6.00866e-14, Final residual = 6.00866e-14, No Iterations 0smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.074003, No Iterations 8bounding k, min: -4.76239e+43 max: 5.53715e+46 average: 5.90803e+44ExecutionTime = 0.25 s ClockTime = 0 sTime = 6smoothSolver: Solving for Ux, Initial residual = 0.314608, Final residual = 0.0114594, No Iterations 2smoothSolver: Solving for Uy, Initial residual = 0.204904, Final residual = 0.00777775, No Iterations 2smoothSolver: Solving for Uz, Initial residual = 0.241948, Final residual = 0.0102625, No Iterations 2GAMG: Solving for p, Initial residual = 1.85243e-08, Final residual = 1.85243e-08, No Iterations 0time step continuity errors : sum local = 4.29755e+38, global = -1.10834e+33, cumulative = -1.10834e+33smoothSolver: Solving for epsilon, Initial residual = 1.58124e-19, Final residual = 1.58124e-19, No Iterations 0smoothSolver: Solving for k, Initial residual = 1.20512e-05, Final residual = 3.47138e-06, No Iterations 1bounding k, min: -1.08061e+62 max: 6.08165e+63 average: 1.49249e+60ExecutionTime = 0.27 s ClockTime = 0 sTime = 7smoothSolver: Solving for Ux, Initial residual = 0.4036, Final residual = 0.0150668, No Iterations 1smoothSolver: Solving for Uy, Initial residual = 0.0563956, Final residual = 0.00216218, No Iterations 1smoothSolver: Solving for Uz, Initial residual = 0.0242237, Final residual = 0.000835869, No Iterations 2GAMG: Solving for p, Initial residual = 4.19126e-13, Final residual = 4.19126e-13, No Iterations 0time step continuity errors : sum local = 1.21558e+38, global = 4.6313e+33, cumulative = 3.52296e+33smoothSolver: Solving for epsilon, Initial residual = 0.310325, Final residual = 0.0239272, No Iterations 3smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0801959, No Iterations 9bounding k, min: -4.70948e+59 max: 7.12389e+77 average: 1.31674e+75ExecutionTime = 0.31 s ClockTime = 0 sTime = 8smoothSolver: Solving for Ux, Initial residual = 0.786814, Final residual = 0.0174761, No Iterations 2smoothSolver: Solving for Uy, Initial residual = 0.944649, Final residual = 0.0311755, No Iterations 1smoothSolver: Solving for Uz, Initial residual = 0.700415, Final residual = 0.0295013, No Iterations 1GAMG: Solving for p, Initial residual = 1.96816e-11, Final residual = 1.96816e-11, No Iterations 0time step continuity errors : sum local = 2.80361e+38, global = -3.46642e+35, cumulative = -3.43119e+35smoothSolver: Solving for epsilon, Initial residual = 0.0791176, Final residual = 1.22877e-28, No Iterations 1bounding epsilon, min: -1.26085e+103 max: 3.80744e+116 average: 5.4922e+113smoothSolver: Solving for k, Initial residual = 0.820595, Final residual = 0.0316278, No Iterations 2ExecutionTime = 0.33 s ClockTime = 1 sTime = 9smoothSolver: Solving for Ux, Initial residual = 0.165546, Final residual = 0.00717691, No Iterations 2smoothSolver: Solving for Uy, Initial residual = 0.162261, Final residual = 0.00629433, No Iterations 2smoothSolver: Solving for Uz, Initial residual = 0.0755672, Final residual = 0.00314139, No Iterations 2GAMG: Solving for p, Initial residual = 0.0813332, Final residual = 0.00748292, No Iterations 6time step continuity errors : sum local = 2.97075e+48, global = -4.08847e+46, cumulative = -4.08847e+46smoothSolver: Solving for epsilon, Initial residual = 3.20318e-10, Final residual = 3.20318e-10, No Iterations 0smoothSolver: Solving for k, Initial residual = 7.7936e-09, Final residual = 7.7936e-09, No Iterations 0ExecutionTime = 0.35 s ClockTime = 1 sTime = 10smoothSolver: Solving for Ux, Initial residual = 0.0883281, Final residual = 0.00437671, No Iterations 30smoothSolver: Solving for Uy, Initial residual = 0.264261, Final residual = 0.0229073, No Iterations 31smoothSolver: Solving for Uz, Initial residual = 0.852793, Final residual = 0.0578588, No Iterations 31GAMG: Solving for p, Initial residual = 0.0138929, Final residual = 9.21681e-05, No Iterations 1time step continuity errors : sum local = 2.99856e+64, global = -3.18673e+60, cumulative = -3.18673e+60smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 0.0304473, No Iterations 2bounding epsilon, min: -1.67737e+138 max: 1.78315e+139 average: 4.3762e+135smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0487917, No Iterations 1bounding k, min: -1.70572e+103 max: 3.69595e+104 average: 4.23868e+101ExecutionTime = 0.4 s ClockTime = 1 sTime = 11smoothSolver: Solving for Ux, Initial residual = 5.24169e-07, Final residual = 5.24169e-07, No Iterations 0smoothSolver: Solving for Uy, Initial residual = 5.9928e-07, Final residual = 5.9928e-07, No Iterations 0smoothSolver: Solving for Uz, Initial residual = 1.30075e-07, Final residual = 1.30075e-07, No Iterations 0#0 Foam::error::printStack(Foam::Ostream&) at ??:?#1 Foam::sigFpe::sigHandler(int) at ??:?#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"#3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?#4 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?#5 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<double>&, Foam::Field<double> const&) const at ??:?#6 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?#7 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?#8 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?#9 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/simpleFoam"#10 Foam::fvMatrix<double>::solve() in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/simpleFoam"#11 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/simpleFoam"#12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"#13 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/simpleFoam"Floating point exception (core dumped) |
Debugging technics - CFD code developing | leo_NM | Main CFD Forum | 2 | June 9, 2016 11:22 |
gdbOF: A debugging Tool for OpenFOAM | nisi | OpenFOAM Announcements from Other Sources | 18 | August 20, 2015 11:43 |
debugging su2 | wangqi198877 | SU2 | 2 | December 8, 2014 09:39 |
Debugging with Eclipse (gdb7.x bug) | hajott | OpenFOAM Programming & Development | 4 | February 18, 2014 05:36 |
Debugging Udfs in Fluent 5.x | Greg Perkins | FLUENT | 0 | April 2, 2001 03:03 |
