Rep Power: 13 ![]() |
Hey everyone,
I haven't found a satisfactory answer in the OpenFoam Guide or Tutorial for the following question: How exactly do the sections 'internalField' and 'boundaryField' of the U- and p-file (in the time folder 0 e.g.) interact? Let's assume, I'm gonna set all cells to 0 m/s in 'internalField' (by syntax for uniform or nonuniform) and going to allocate the certain cells of the inlet boundary with 1 m/s in 'boundaryField' (what are obviously a part of the cells in 'internalField'). Will the values for the inlet cells be overwritten from 0 to 1 m/s???
Kind Regards Karman |
Michael Alletto
Rep Power: 16 ![]() |
Boundary values are fixed (if fixed value is chosen) and internalField values are calculated by solving the system of equations
twoPhaseEulerFoam confined plunging jet simulation failed | ves | OpenFOAM Running, Solving & CFD | 2 | June 17, 2020 05:08 |
internalField in boundaryField | yambanshee | OpenFOAM Pre-Processing | 1 | April 23, 2019 16:16 |
error in fireFoam, when running the case wallFireSpread2D | zhoubiao1088 | OpenFOAM Running, Solving & CFD | 9 | February 1, 2018 18:45 |
Create internalfield from boundaryfield | Dharoc | OpenFOAM Programming & Development | 0 | December 17, 2017 11:17 |
Difference between 'internalField' and 'boundaryField'? | Rusty Velo | OpenFOAM | 21 | September 20, 2016 06:29 |
