How to write these time-dependent equation (PEM Fuel Cell) |
October 1, 2024, 06:33 |
#41 |
Lasse Brams Vinther
Rep Power: 11 |
Hello Ron,
Just checked the case, as I hadn't touched it in the process of updating the solver. Ran it just with a single processor, and it worked fine at least. From what I can see the solver needs a parprep directory and this is not a part of the case but I believe its quite similar to the HTPEM solver from Jülich, I will try and give it a whirl, however, some changes must be made the case and therefore the general solver from my knowledge at least, mainly combining the bp regions into one for decomposition reference as its required with the mentioned decomposition method. I'm currently in contact with the original HTPEM cell code developer regarding making it available as I can't find it at the old repository anymore. All of the decomposition is most likely very similar and would allow you to set it up yourself as my time sadly is limited. A brief flow of the decomposition looks like this, but requires a custom decomposer using a gauge mesh being the bpp mesh in the cells generating the CellID directories, the command makemesh3dFoam from the HTPEM solver. Note region1 is due the generating the mesh with snappyHexMesh where the ambient mesh is not designated a region and therefore results in region1 which we then translate to interconnect. Code:
#!/bin/sh ## edit system/decomposeParDict for the desired decomposition ## set environment variable NPROCS to number of processors. ## e.g., setenv NPROCS 2 ## make mesh ## ## then: #!/bin/bash rm -rf constant/*/cellID rm -rf constant/cellID echo "NPROCS = " $NPROCS makemesh3dFoam rm -rf constant/region1 cp -rf constant/interconnect constant/region1 cp system/decomposeParDictSim system/decomposeParDict cp -rf system/decomposeParDict system/air/. cp -rf system/decomposeParDict system/fuel/. cp -rf system/decomposeParDict system/interconnect/. cp -rf system/decomposeParDict system/electrolyte/. rm -rf system/region1 cp -rf system/interconnect system/region1 # To reconstruct and visualize the regions, we need the *ProcAddressing files # created by decomposePar -region <region name> # After the region decomp, we rename the processor* directories as proc_* # to (a) allow the parallel decomp to proceed # while (b) saving the *ProcAddressing files for later copy decomposePar -force decomposePar -region air decomposePar -region fuel decomposePar -region electrolyte decomposePar -region region1 mpirun -np $NPROCS foamExec splitMeshRegions -cellZones -parallel I=0 while [ $I -lt $NPROCS ] do rsync -av processor$I/constant/ processor$I/1/ cp -rf processor$I/1/. processor$I/constant/. rm -rf processor$I/1 cp -rf processor$I/constant/region1 processor$I/constant/interconnect I=$((I+1)) done mpirun -np $NPROCS foamExec topoSet -region fuel -parallel mpirun -np $NPROCS foamExec topoSet -region air -parallel |
October 2, 2024, 09:44 |
#42 | |
Rep Power: 4 |
now I tried such a custom decomposer, resulting in a very nice kind of processor map, as shown in the attached figure for the cathodeFluid only. I can run the CFD until ~20its, but then its crashing again. Dump: Solving cathode liquid water saturation DILUPBiCG: Solving for S, Initial residual = 0.9893958, Final residual = 1.07864e+12, No Iterations 1000 ScathodeLiquidWater min mean max = -8.829769e+11 -6.783752e+10 8.668707e+11 I mean it's important not to have cut planes through channel regions, which is here not the case anymore. Another option for improvements might be to test a finer base mesh... cheers, Ron |
October 2, 2024, 10:43 |
#43 | |
Rep Power: 4 |
SOLVED,
I changed the setting to solve the S scalar for the cathodeFluid: S { solver GAMG; smoother GaussSeidel; tolerance 1e-13; relTol 0.0; nPreSweeps 0; preSweepsLevelMultiplier 1; maxPreSweeps 4; nPostSweeps 2; postSweepsLevelMultiplier 1; maxPostSweeps 4; nFinestSweeps 2; interpolateCorrection no; scaleCorrection yes; // Yes: symmetric No: Asymmetric directSolveCoarsest no; } Not sure, whether all those settings really make sense, but it succeeded. The logfile is attached. cheers, Ron Quote:
October 2, 2024, 11:15 |
#44 | |
Rep Power: 4 |
Attached is the empty case zipped now.
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 12:04 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 06:49 |
[Helyx OS] Helyx-OS (GUI for SnappyHexMesh | elvis | OpenFOAM Community Contributions | 210 | January 30, 2017 19:57 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
