Implementing fourth order tensor?
Old   June 21, 2020, 05:50
Default Implementing fourth order tensor?
Matias Haapalehto
haapalm is on a distinguished road
I need to implement the following equation (attached) which involves a fourth order tensor. As far as I know these are not readily available in OpenFOAM.
What would be the best way to go about implementing a fourth order tensor and the corresponding operations in OpenFOAM?
I have looked into this: https://math.stackexchange.com/a/3026704
would that mean that I would implement it as a 9-by-9 Foam::vector of Foam::vectors?
Thank you for your help!
Matias
haapalm is offline   Reply With Quote
Old   June 21, 2020, 06:12
Santiago Lopez Castano
Santiago is on a distinguished road
That would be a bad idea. You just need to create a struct: follow the definition of the Tensor class
Santiago is offline   Reply With Quote
Old   June 21, 2020, 06:44
Matias Haapalehto
Thank you for your answer. I am not sure what the struct would look like, would it simply contain 81 scalars?
As far as I see the tensor class inherits from the MatrixSpace class, would I need to do the same only with a 9-by-9 matrix?
Matias
Old   June 21, 2020, 13:41
Matias
you can extend the VectorSpace class, in the same way Tensor does:
/* TENSOR 2nd rank*/
  template<class Cmpt>
  class Tensor
      public VectorSpace<Tensor<Cmpt>, Cmpt, 9>
Then implement all basic operations like transpose, inner-(outer) products, duals, etc....
Old   June 21, 2020, 17:58
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
- I know arbitrary-order tensors and matrices are different in terms of their mathematical properties. But, is there any chance for you to designate your problem as a set of matrix operations, rather than tensor?
- If you can use matrices for your problem, I would use the class template: Matrix<Type> in OF.
HPE is offline   Reply With Quote
Divergence of third order tensor maka OpenFOAM Post-Processing 1 July 4, 2024 15:30
Solving a fourth order PDE debanik1 Main CFD Forum 4 November 9, 2016 18:39
Help for fourth order accurate convective schemes Z.C.Wang Main CFD Forum 0 January 15, 2009 07:53
Fourth order surface normal gradient interpolation adona058 OpenFOAM Running, Solving & CFD 8 September 24, 2007 16:12
2nd order Tensor Divergence Mistake in Programmerbs Guide vvqf OpenFOAM 3 December 2, 2005 05:53
