Writing custom function of flow field at every iteration
Old   June 20, 2020, 18:16
Default Writing custom function of flow field at every iteration
Suraj Pawar
sap_92 is on a distinguished road
I have a question related to controlling the frequency at which the solution field is written in the folder. I can control the frequency of solution writing in controlDict using below parameters
writeControl timeStep;
writeInterval 200;
Basically, this will write a solution after every 200 time steps.
Now, I would like to create a custom function which computes the magnitude of velocity over the whole domain (sum of square of velocity u at every grid point) and write this variable to a text file or csv file at every time step while the simulation is running. How can I do it? I wont to keep the frequency of writing the entire solution (u,v,k,...) at 200 time steps only. Can someone please point me to resources that guides on how to create a custom function to compute some quantity at every time step in OpenFoam?
sap_92 is offline   Reply With Quote
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 19:19
Problem in sampling data of custom field function in ANSYS FLUENT v14 apek_great ANSYS 1 February 26, 2014 06:10
Mass Flow Rate Field Function RonBon STAR-CCM+ 0 February 19, 2013 09:58
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
