Overset solver command-line options in foam-extend 4.1
Old   June 18, 2020, 15:05
Default Overset solver command-line options in foam-extend 4.1
Vivio is on a distinguished road
Hi everyone,
Very quick question.
I'm using overset in foam-extend 4.1 with the solvers icoOversetFoam and simpleOversetFoam. The overset fringe assembly is built into the solver so as soon as you call the solver, it automatically does the grid assembly, designating hole/donor/acceptor cells.
However, there is a command-line option you can pass to just do the grid assembly, but stops before the solver is called, leaving you with just the field output for the oversetTypes and RegionID, and information on the grid assembly.
Does anyone remember what the command option is? I can't find it documented anywhere, nor wherever its located in the source code.
Best regards,
Vivio
Vivio is offline   Reply With Quote
Old   January 26, 2021, 10:26
Saleh Abuhanieh
Saleh Abuhanieh is on a distinguished road
calcOverset
Saleh Abuhanieh is offline   Reply With Quote
overset foam-extend
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
