June 18, 2020, 02:46 |
Strange Problem facing in running SprayFoam
krishna kant
Rep Power: 10 |
Hello All,
I am trying to create a setup case in sprayFoam, where I want to study liquid jet breakup using the Eulerian-Lagrangian method. Ideally, I want both fluids to be treated as an incompressible flow. There will be no reaction and combustion. But evaporation and phase change is allowed. Also Later on I want to do thin film modeling too. Currently, the problem I am facing is strange. Here is the execution print that I am getting: Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading g Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture multiComponentMixture; transport const; thermo hConst; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } Creating component thermo properties: multi-component carrier - 2 species liquids - 1 components solids - 0 components Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type laminar Selecting laminar stress model Stokes Creating combustion model Combustion model not active: combustionProperties not found Selecting combustion model none Creating field dpdt Creating field kinetic energy K No MRF models present Constructing reacting cloud Constructing particle forces Selecting particle force sphereDrag Constructing cloud functions none Constructing particle injection models Creating injector: model1 Selecting injection model patchInjection Constructing 3-D injection Selecting distribution model RosinRammler Selecting dispersion model none Selecting patch interaction model standardWallInteraction Selecting stochastic collision model none Selecting surface film model none Selecting U integration scheme Euler Selecting heat transfer model RanzMarshall Selecting T integration scheme analytical Selecting composition model singlePhaseMixture Selecting phase change model liquidEvaporationBoil Participating liquid species: H2O Selecting atomizationModel none Selecting breakupModel ReitzDiwakar Average parcel mass: 2.4e-09 Radiation model not active: radiationProperties not found Selecting radiationModel none No finite volume options present As it is not showing any error message I don't know what is going wrong in it. But it should have calculated the courant number before entering in a time loop. I am attaching my case study please have a look into it. Any guide/help/suggestion will be deeply appreciated. I need to resolve this urgently. |
October 25, 2021, 07:14 |
Juan Gomez
could you find a solution for your problem?i have exactly the same problem with buoyantPimpleFoam. it just stopt withourt running
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 9-a0f1846504f2 Exec : buoyantPimpleFoam Date : Oct 25 2021 Time : 13:09:08 Host : "fmp-pc-132" PID : 10845 I/O : uncollated Case : /mnt/c/Users/J.Gomez/tutorial/tutorials/heatTransfer/buoyantPimpleFoam/dryer nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: No convergence criteria found PIMPLE: Operating solver in transient mode with 1 outer corrector PIMPLE: Operating solver in PISO mode Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model realizableKE RAS { model realizableKE; turbulence on; printCoeffs on; A0 4; C2 1.9; sigmak 1; sigmaEps 1.2; } Creating thermophysical transport model Selecting thermophysical transport type RAS Selecting default RAS thermophysical transport model unityLewisEddyDiffusivity Reading g Reading hRef Calculating field g.h Reading pRef Reading field p_rgh Creating field dpdt Creating field kinetic energy K No MRF models present No fvModels present No fvConstraints present |
Problem running in parallel with patch and patchField | Byba | OpenFOAM | 1 | April 27, 2021 09:27 |
Problem in running coarse mesh(on the other hand fine mesh is running) | ashokmoravaneni | OpenFOAM | 7 | July 17, 2017 04:56 |
SceneGraph.dll problem when running RSM on CentOS | Lukasz | CFX | 1 | November 29, 2016 07:16 |
Problem while running in Highperformance computing environment | Phanipavan | STAR-CD | 1 | September 11, 2013 06:42 |
backward facing step problem | Yung-Ming Chen | Main CFD Forum | 3 | May 11, 1999 22:04 |
