Abnormal result of dynamic mesh motion at the between bottom and side boundary.
Old   June 17, 2020, 22:39
Default Abnormal result of dynamic mesh motion at the between bottom and side boundary.
Chaewoong Ban
blue8803 is on a distinguished road
I'm trying to solve Exner equation (mass conservation equation of sediment phase) using FAM and mesh move is implemented using dynamic mesh motion. My test case is U-shape open channel flow composed of bottom wall (patch name: bed), side wall (patch name:sidewall), inlet, outlet. First, only flow is simulated until flow is fully developed (it is not problem). After that, turn on my implemented code, morphological changes start. At the beginning, it seems good, but some time later problem occur at the vicinity of the sidewall near the bed (please refer to attached picture). It seems that the sidewall is correctly moved in the mesh motion stage. What causes the problem..?
Thank you for any questions or answers!
Here is boundary condition for motionU.
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (0 0 0);
outlet
type fixedValue;
sidewall
type slip;
} /// I think it is right..
bed
type fixedValue;
atmosphere
type fixedValue;
I'm now suspicious of relTol....
solvers
motionU
solver PCG;
preconditioner DIC;
tolerance 1e-09;
relTol 0.001;
In the dictionary file dynamicMeshDict, what means the twoDMotion??
dynamicFvMeshLibs ("libdynamicTopoFvMesh.so");
//- Select the type of dynamicFvMesh
dynamicFvMesh dynamicMotionSolverFvMesh; //dynamicTopoFvMesh;
twoDMotion yes;
//- Select the type of motionSolver
//solver laplace;
RBFMotionSolver /dynamicMeshDict/movingPatches
displacementComponentLaplacian
displacementInterpolation /dynamicMeshDict/displacementInterpolationCoeffs
displacementLaplacian /0/pointDisplacement
displacementSBRStress /0/pointDisplacement
laplace
mesquiteMotionSolver /dynamicMeshDict/mesquiteMotionSolver
pseudoSolid /dynamicMeshDict/pseudoSolid
refVelocityLaplacian /0/pointMotionU
velocityComponentLaplacian
velocityLaplacian /0/pointMotionU
solver laplace;
diffusivity quadratic inverseDistance;
distancePatches 1 (bed);
frozenDiffusion off;
I reseachred some source code but,, i didn't reach understanding.
src/dynamicMesh/dynamicMesh/motionsolver/motionSolver.H
// Member Functions
//- Return true for 2-D motion
bool twoDMotion() const
return twoDPointCorrector_.required();
src/meshTools/twoDPointCorrector/twoDPointCorrector.C
/*Description
Class applies a two-dimensional correction to mesh motion point field.
The correction guarantees that the mesh does not get twisted during motion
and thus introduce a third dimension into a 2-D problem.*/
// * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * //
twoDPointCorrector::twoDPointCorrector(const polyMesh& mesh)
mesh_(mesh),
required_(mesh_.nGeometricD() == 2), ///??????????????
planeNormalPtr_(nullptr),
normalEdgeIndicesPtr_(nullptr)
File Type: jpg Screenshot from 2020-06-18 12-29-15.jpg (139.0 KB, 23 views)
File Type: jpg Screenshot from 2020-06-18 12-28-49.jpg (176.7 KB, 22 views)
blue8803 is offline   Reply With Quote
Old   June 18, 2020, 07:19
Santiago Lopez Castano
Santiago is on a distinguished road
which solver is this?
Santiago is offline   Reply With Quote
Old   June 19, 2020, 09:30
Chaewoong Ban
I used the solver I made based on the interDyMFoam or pimpleDyMFoam.
Old   June 19, 2020, 09:58
/*Description
mesh_(mesh),
I think the description of the class is rather clear: the grid nodes will not twist for a 2D problem.
The statement:
Is asking whether the GRID is 2D. Obviously the 2D correction algorithm doesnt make much sense in 3D grids, specially in bed erosion problems. I assume you are following Xiafeng Liu's work then, unless you are running a 2D case (where you have wedges/empty patches), setting
twoDMotion yes;
is not correct.
The motion solver seems correct to me, not very convinced of you BCs for motionU but, in order for me to give you an informed opinion, I need to see the implementation of the finiteArea model + the faMesh...
Old   June 22, 2020, 02:59
Chaewoong Ban
The statement:
twoDMotion yes;
is not correct.
Many thanks for your reply.
This is the piece of my code.
(bedload calculation)
(solving Exner equation)
(solving mesh motion)
tetPointVectorField& motionU =
const_cast<tetPointVectorField&>
  mesh.lookupObject<tetPointVectorField>
    "motionU"
fixedValueTetPolyPatchVectorField& motionUaPatch =
refCast<fixedValueTetPolyPatchVectorField>
  motionU.boundaryField()[aPatchID]
tetPolyPatchInterpolation tppiAPatch
  refCast<const faceTetPolyPatch>
    motionUaPatch.patch()
primitivePatchInterpolation patchInterpolator (mesh.boundaryMesh()[aPatchID]);
scalarField faceVal = patchInterpolator.faceToPointInterpolate(deltaH);
vectorField dH (Psize);
forAll(dH, i)
  dH[index].x() = 0;
  dH[index].y() = 0;
  dH[index].z() = faceVal[i];
motionUaPatch == tppiAPatch.pointToPointInterpolate (dH/mesh.time().deltaT().value());
//motionUaPatch == tppiAPatch.pointToPointInterpolate (dH);
meshChanged1 = mesh.update();
reduce(meshChanged1, orOp<bool>());
(sand-sliding)
(interFoam)
Also, I have tested some factors.
(i) relTol in dynamicMeshDict
0, 1e-3
(ii) diffusivity in dynamicMeshDict
inverseDistance, inverseFaceDistance, inversePointDistance with linear manipulator
inverseDistance, inverseFaceDistance, inversePointDistance with qudratic manipulator
(iii) twoDMotion in dynamicMeshDict
yes, no
In fact, there is no significant impact on final results considering above different factors..
Now I made a case rather simple. only one face are upward in constant motionU velocity (in code deltaH(somewhere on face) = 0.2), and found that at the sidewall upper layer of the cell moving upward converged each others (see picture).
Old   June 22, 2020, 03:11
Default pic
Chaewoong Ban
I really don't know why they are converged
File Type: jpg InkedScreenshot from 2020-06-22 17-05-50_LI.jpg (154.3 KB, 16 views)
File Type: jpg Screenshot from 2020-06-22 17-11-41.jpg (172.7 KB, 22 views)
Old   June 22, 2020, 06:01
Default I may narrow the resoans for problem
Chaewoong Ban
With turning off the sand-sliding features, mesh motion is works fine. However, I think it is not the problem of the sand-sliding model I made, but the iterative positive/negative values of motionU are the major reasons.
Because there is no steep slope that activate sand-sliding model in the first simulation (U-shape channel flow). So, i dig into this perspective
File Type: jpg Screenshot from 2020-06-22 19-39-34.jpg (115.7 KB, 15 views)
File Type: jpg Screenshot from 2020-06-22 19-39-42.jpg (115.7 KB, 13 views)
File Type: jpg Screenshot from 2020-06-22 19-39-44.jpg (116.5 KB, 16 views)
Old   July 2, 2020, 06:46
Default (solved)
Chaewoong Ban
Many thanks.
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Solver error message!!! IoSa CFX 1 September 14, 2006 05:48
