Laser DTRM Feature in icoReactingMultiphaseInterFoam |
June 17, 2020, 18:48 |
Rep Power: 6 |
I am attempting to use the Laser DTRM feature with the icoReactingMultiphaseInterFoam solver. I am trying to model a moving laser. When the laser is stationary, heat is transferred as expected, but when it moves (as below), the barely any heat is transferred. Am I missing something, or is there a better radiation model to use?
radiationModel laserDTRM; absorptionEmissionModel constantAbsorptionEmission; mode "Gaussian"; nTheta 70; nr 30; focalLaserPosition table ( (0 (0.000500 0.000150 0.000125)) (0.0002 (0.000750 0.000150 0.000125)) ); laserDirection constant (0 0 -1); focalLaserRadius 0.000050; laserPower 1200; sigma 0.000049; absorptivity absorptivity [0 -1 0 0 0 0 0] 0.8; emissivity emissivity [0 -1 0 0 0 0 0] 0.4; E E [1 -1 -3 0 0 0 0] 0; |
October 15, 2020, 20:34 |
#2 | |
Anonymous.
Rep Power: 6 |
This is mine incase you want to check. radiation on; radiationModel laserDTRM; // Number of flow iterations per radiation iteration solverFreq 5; absorptionEmissionModel constantAbsorptionEmission; mode "Gaussian"; nTheta 20; nr 10; opd 0.1; //focalLaserPosition constant (0.025 0.05 0.05); focalLaserPosition table ( (0 (0.025 0.02 0.05)) (160 (0.025 0.2 0.05)) ); laserDirection constant (0 0 -1); focalLaserRadius 0.005; laserPower 50000;//mW? sigma 0.005; //qualityBeamLaser 1.0; absorptivity absorptivity [0 -1 0 0 0 0 0] 0.8; emissivity emissivity [0 -1 0 0 0 0 0] 0.4; E E [1 -1 -3 0 0 0 0] 0; scatterModel none; sootModel none; transmissivityModel none; Im not sure if the laser power is of mW unit or W unit as I could only get higher temperature when I assume it is mW. |
December 30, 2020, 03:19 |
#3 | |
Rep Power: 14 |
In the table for focalLaserPosition, what does the first number and the vector mean? Thank you very much! focalLaserPosition table ( (0 (0.025 0.02 0.05)) (160 (0.025 0.2 0.05)) ); Quote:
June 2, 2021, 04:30 |
#4 | |
Teresa
Rep Power: 10 |
@Gentodin and mattms If not enough heat is transmitted during movement you may want to recalculate the laser velocity (movement made between two points in the table). However, maybe there is enough heat transmitted but it is "consumed" by the phase above your solid? You might not see this at first but check the temperature field shortly after you started the laser. If that is the problem use localDensityAbsorptionEmissionCoeffs, e.g.: Code:
localDensityAbsorptionEmissionCoeffs { alphaNames (alpha.gas alpha.liquid alpha.solid); aCoeff (0 1e3 1e8); eCoeff (0 0.35 0.35); ECoeff (0 0 0); } |
icoReactingMultiphaseInterFoam Laser DTRM | OPFO | OpenFOAM Running, Solving & CFD | 42 | August 19, 2022 01:29 |
[snappyHexMesh] Failed Edge Snap with box geometry and correct feature capture | thiagomarinho | OpenFOAM Meshing & Mesh Conversion | 7 | May 7, 2022 09:19 |
[snappyHexMesh] surfaceFeatureExtract error- Feature line extraction? | anu.raghun | OpenFOAM Meshing & Mesh Conversion | 2 | July 2, 2019 10:43 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] Explicit feature edge ref&snap in OF2.2 | Eloise | OpenFOAM Meshing & Mesh Conversion | 0 | May 9, 2014 11:39 |
