sloshing2D tutorial OpenFOAM 4.1-extend
Old   June 17, 2020, 13:56
Default sloshing2D tutorial OpenFOAM 4.1-extend
Josh McCraney
joshmccraney is on a distinguished road
Hi all!
The sloshing2D tutorial via OpenFOAM 4.1-extend runs well (this tutorial is a 2D channel, top filled with gas, bottom with liquid, initially deformed. The meniscus oscillates upon starting simulation). However, I am confused on three points, and would love any clarification you can have:
1) There is no setFields file (which I'm used to seeing in interFoam) so how is the initial sinusoidal interface being set?
2) There is no blockMesh file, so how is the mesh and grid size set?
3) How to track the interface through time. Through interFoam I've always opened paraFoam, then located the alpha = 0.5 value (which gives a line along the interface) and then saved all outputs to a file.
I'd really appreciate your help!
joshmccraney is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
foam extend and OpenFOAM reach different results samanngh OpenFOAM Running, Solving & CFD 9 July 12, 2022 22:34
[FSI] HronTurek Tutorial OpenFoam extend: no flag movement roma-aeterna OpenFOAM CC Toolkits for Fluid-Structure Interaction 13 October 15, 2019 05:11
fluxRequired OpenFoam Versions SimpleFoam Taylor Couette flow tutorial mörli OpenFOAM Running, Solving & CFD 0 April 9, 2019 12:50
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 06:40
