Need some information on how to use FvSchemes
Old   June 16, 2020, 05:31
Post Need some information on how to use FvSchemes
Lucie Recurt
lucie.recurt is on a distinguished road
Hey,
I'm currently a intern in a startup and I have to work on OpenFoam.
I'm trying to understand the differencies between all the fvScheme that I can use. I started with the ddt schemes. I read the specificity of each and that Crank-Nicolson 0.9 is the most robust. But when I use this scheme, I got this error message:
Courant Number mean: 0.0112231 max: 7.96644
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
#4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
#5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 ? in "/opt/openfoam-dev/platforms/linux64GccDPInt32Opt/bin/icoFoam"
#7 ? in "/opt/openfoam-dev/platforms/linux64GccDPInt32Opt/bin/icoFoam"
#8 ? in "/opt/openfoam-dev/platforms/linux64GccDPInt32Opt/bin/icoFoam"
#9 ? in "/opt/openfoam-dev/platforms/linux64GccDPInt32Opt/bin/icoFoam"
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? in "/opt/openfoam-dev/platforms/linux64GccDPInt32Opt/bin/icoFoam"
Exception en point flottant (core dumped)
Do someone know why?
And do you have good documents that explain very well how to use each scheme?
Best regards;
Lucie
lucie.recurt is offline   Reply With Quote
cranck-nicolson, ddtschemes, fvschemes, time setting
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
rhoSimpleFoam doubts on BC and fvSchemes (external aero) giovanni.medici OpenFOAM Running, Solving & CFD 3 October 27, 2021 06:06
script for export particle information archetype CFX 2 August 8, 2017 10:57
OpenFOAM 2D simulation - Freelancer Job- Information will be provided sanjar CFD Freelancers 0 March 7, 2017 10:45
information from saved data files:Unsteady flow Atul FLUENT 5 July 27, 2008 21:05
