Steady solver for high-transonic flows
Old   June 13, 2020, 11:13
Question Steady solver for high-transonic flows
Tom
tom.opt is on a distinguished road
Hi all,
I was wondering if there's any solver in the Openfoam framework that is suited for transonic flows where Mach number is 0.95-1.3;
I have tried rhoSimpleFoam with transonic option but it proved to be unreliable and often unexplainably crash.
Running transient solvers is not an option as I do not have to computational power required for my problem.
I'm simulating an aircraft that's 10m in length and the computational domain is 100m in each direction.
tom.opt is offline   Reply With Quote
Old   June 15, 2020, 21:20
Klaus
klausb will become famous soon enough
many factors influence stability - it's difficult to help without information:
What's your case setup? fvSchemes, fvSolution
What kind of mesh do you use?
Do you have any idea of the mesh quality?
What's the mesh size?
What hardware do you use: CPU, GPU, RAM?
Klaus
klausb is offline   Reply With Quote
density based solver, rhosimplefoam, transonic aircraft
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 06:02
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
steady solver in openfoam!! milad653279 OpenFOAM Running, Solving & CFD 3 December 6, 2015 08:56
TUI Transient solver to Steady solver mbell10 FLUENT 1 February 2, 2011 09:53
