Help: rhoCentralFoam de Laval Nozzle supersonic shock waves |
June 10, 2020, 12:57 |
Vignesh Veeresparan
Rep Power: 9 |
I'm trying to simulate supersonic flow in nozzle using rhoCentralFoam for couple of weeks now. I have gone through the multiple posts on this forum and nothing helped in solving my issue. So, reaching to you guys at least few could help me in addressing my issue. Problem Statement:- Supersonic flow in nozzle to understand shock waves Inputs:-Nozzle is designed with stagnation pressure of 2.26e+06 pa, stagnation temperature of 1200k where the flow exits to pressure of 38521 pa. Following are the Boundary conditions used p Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 38521; boundaryField { inlet { //type fixedValue; //value uniform 2.267e+6; type totalPressure; p0 uniform 2.267e+6; value uniform 2.267e+6; } outlet { type waveTransmissive; value uniform 38521; field p; gamma 1.4; lInf 100; fieldInf 38521; } nozSym { type symmetryPlane; } wall1 { type zeroGradient; } wall2 { type zeroGradient; } nozWall { type zeroGradient; } frontAndBackPlanes { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 1200; boundaryField { inlet { type totalTemperature; gamma 1.4; T0 uniform 1200; } outlet { type zeroGradient; } nozSym { type symmetryPlane; } wall1 { type zeroGradient; } wall2 { type zeroGradient; } nozWall { type zeroGradient; } frontAndBackPlanes { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type pressureInletOutletVelocity; phi phi; value uniform (0 0 0); } outlet { type zeroGradient; } nozSym { type symmetryPlane; } wall1 { type slip; } wall2 { type slip; } nozWall { type slip; } frontAndBackPlanes { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object thermophysicalProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // thermoType { type hePsiThermo; mixture pureMixture; transport const; //transport sutherland; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } mixture { specie { nMoles 1; molWeight 28.9; } thermodynamics { Cp 1005; Hf 0; } transport { //mu 1.84e-05; mu 0; Pr 0.713; As 1.4792e-06; Ts 116; } } //dpdt no; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object turbulenceProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // simulationType laminar; /* RAS { RASModel kOmega; turbulence on; printCoeffs on; } */ // ************************************************************************* // Issue:- Floating Point Exception. Solution runs for some time and gets terminated after some time step. I have attached controlDict, fvSchemes and fvSolutions if anyone really wants to have a look at it. It doesn't have any issue with mesh and checkMesh returned OK. I understand the problem has ill-posed BC or setup. openFoam experts seeking your advise to direct me to right approach. Regards, VV Last edited by vizvaz; June 11, 2020 at 03:20. Reason: Added Issue to the Post |
February 12, 2022, 06:12 |
Any Updates???
Hey, I am also working on the same problems with similar boundary conditions. If you were able to solve the problem, can you share the details here?
August 15, 2022, 09:27 |
PhD student
Hello, I am in trouble with 2D RANS supersonic jet fire. Similar boundary conditions and same error (float exception). Did you solve this problem? If you did, would you like help me? Thanks very much.
Fluent and supersonic flows with strong shock waves | gera | FLUENT | 13 | December 15, 2015 06:21 |
De laval Supersonic Nozzle Exit Mach number in CFX | bharath | CFX | 7 | December 19, 2014 03:44 |
supersonic (Laval) nozzle, unphysical Mach number | Judith | CFX | 7 | August 14, 2014 19:28 |
Looking for an explanation for two weak oblique shock waves inside de Laval nozzle | heksel8i | Main CFD Forum | 2 | December 5, 2013 03:23 |
Convergence Problem Supersonic Flow Laval Nozzle | Tobias | CFX | 3 | December 7, 2005 02:23 |
