rhoPimpleFoam hangs for collated I/O
Old   June 10, 2020, 11:56
Question rhoPimpleFoam hangs for collated I/O
Miguel Castellano
michu5696 is on a distinguished road
Hi!
So just what it's written on the title, when trying to run rhoPimpleFoam with the collated filaHandler it just hangs. It remains blocked forever.
After many many trials and lots of time spent tying to spot the problem I've come to realize it is nothing related to the OpenFOAM version, nor the MPI backend or threading capabilities of the latter. It must merely be a question of how the case is built, since I've run it on other tutorial cases under the same circumstances and it worked smoothly.
The workflow is the ordinary:
>> blockMesh
>> decomposePar -fileHandler collated
>> mpirun -np 4 rhoPimpleFoam -parallel -fileHandler collated
and BINGO!
Build : _f3950763fe-20191219 OPENFOAM=1912
Arch : "LSB;label=32;scalar=64"
Exec : rhoPimpleFoam -parallel -fileHandler collated
Date : Jun 10 2020
Time : 16:31:01
Host : michu-laptop
PID : 279801
I/O : collated (maxThreadFileBufferSize 0)
Threading not activated since maxThreadFileBufferSize = 0.
Writing may run slowly for large file sizes.
--- HANGS IN HERE FOREVER ----
* Note that I set maxThreadFileBufferSize to 0 in $FOAM_ETC/controlDict so you don't tell it is because my MPI implementation doesn't support threading. I've tested both Gcc and Icc compilations with impi and openmpi.
Here's the simplified case on github so you can clone it, run it and see it for yourselves.
git clone git@github.com:michu5696/ashee.git
Since I'm no OpenFOAM expert, could you explain to me what is wrong with this case?
Thanks a lot in advance!!
michu5696 is offline   Reply With Quote
Old   July 7, 2020, 09:59
Default Solved!
Miguel Castellano
Ok. For anybody experiencing the same problem. I just figured out. It took me some time and honestly it's the stupidest thing ever. This must be a bug in the implementation of collated output.
For some reason, if you set your dictionary variables from a personal dictionary by adding
"#include mydict"
the collated fileHandler hangs forever.
End of story.
Old   July 20, 2020, 11:13
Joachim Herb
jherb is on a distinguished road
Have you filed a bug at https://bugs.openfoam.org/rules.php ?
jherb is offline   Reply With Quote
Old   July 21, 2020, 09:18
Miguel Castellano
Yes!
https://develop.openfoam.com/Develop.../-/issues/1765
Old   November 16, 2020, 21:54
Bodo1993 is on a distinguished road
"#include mydict"
End of story.
Thanks a lot.
Your post was very helpful. I got stuck on the same issue until I saw it.
I had to remove the #include from the decompseParDict and enter the number of subdomains manually.
The suggested workaround from the bug report did not help me as I got errors too.
I am wondering if you managed to resolve your issue while keeping the #include in the decompseParDict file. Thanks.
Bodo1993 is offline   Reply With Quote
Old   December 28, 2022, 05:06
koray is on a distinguished road
I've only deleted foamdatatofluentdict file and restarted the job. It worked...
koray is offline   Reply With Quote
collated, i/o, rhopimplefoam
pimpleFoam runs slower than rhoPimpleFoam Kosuke Seto OpenFOAM Running, Solving & CFD 3 May 27, 2023 15:12
rhoPimpleFoam Boundary Condition Problem dancfd OpenFOAM Pre-Processing 18 September 16, 2021 08:43
rhoPimpleFoam gives stranger result ... and doesn't work kin3062 OpenFOAM Running, Solving & CFD 16 April 12, 2019 08:46
Pressure stair-step behaviour using rhopimplefoam joegi.geo OpenFOAM Running, Solving & CFD 3 December 12, 2014 13:10
rhoPimpleFoam floating point error dancfd OpenFOAM Running, Solving & CFD 6 January 5, 2014 21:57
