CyclicAMI BC error
Old   June 10, 2020, 05:35
Default CyclicAMI BC error
Nat K
nskelly is on a distinguished road
I have been using foam-extend 3.2 to perform some simulations and have come into some problems with meshing and solving.
Just to note, I have used this exact same mesh and boundary conditions in OF 5 and did not receive any of the following problems.
It is a simple backward facing step geometry with inlet, outlet, upperwall and lowerwall, front and back.
I want to apply cyclic boundary conditions to the front and back but when meshing I get errors regarding the face areas do not match. I also tested this out on the pitzDaily tutorial and the same problem occurred.
Searching forums showed that using cyclicAMI helps with this problem, and it did and I was able to create a mesh fine.
However, when I apply boundary conditions using cyclicAMI and trying to solve the case I get the following error.
--> FOAM FATAL ERROR:
    gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type cyclicAMI)
    on patch front of field U in file "/data1/foam/nk583-3.2/bfs_test/locDynEddy_visco/0/U"
    You are probably trying to solve for a field with a generic boundary condition.
    From function genericFvPatchField<Type>::gradientInternalCoeffs() const
    in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 811.
FOAM exiting
0/U:
| \\      /  F ield         | foam-extend: Open Source CFD                    |
|  \\    /   O peration     | Version:     3.2                                |
|   \\  /    A nd           | Web:         http://www.foam-extend.org         |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            turbulentInlet;
        referenceField  uniform (0.75 0 0);
        fluctuationScale (0.02 0.01 0.01);
        value           uniform (0.75 0 0);
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
        value           uniform (0 0 0);
    upperWall
        type            fixedValue;
    lowerWall
        type            fixedValue;
    front
        type            cyclicAMI;
        value           $internalField;
    back
        type            cyclicAMI;
Any ideas what this error refers to?
Thanks in advance!
nskelly is offline   Reply With Quote
Old   June 11, 2020, 06:39
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
With foam-extend you need to use GGI instead of AMI, they are similar as they allow for nonconformal interfaces, but the implementation differs between them. Please have a look into tutorials for GGI with foamExtend.
Regards,
Tom
tomf is offline   Reply With Quote
Old   June 11, 2020, 10:37
Nat K
I have just tried to use the cyclicGGI BC and I receive the same error.
I'm not sure how to find tutorials in foam-extend as foamSearch command does not work. Do you know of any tutorials that specifically use cyclicGGI?
I also don't understand why the basic cyclic BC does not work for such a simple geometry.
Thanks
Old   June 12, 2020, 04:41
Tom Fahner
It is called ggi in foam-extend, not cyclicGGI, so that is why you have the error, which basically says that the name cyclicGGI/cyclicAMI is not known to foam-extend.
You can find some tutorials like this:
grep -r ggi $FOAM_TUTORIALS
from a terminal.
Then you just need to find the one that is closest to your problem.
Regards,
Tom
Old   June 15, 2020, 11:42
Nat K
Using ggi seems work, although I do not exactly know what it does that 'cyclic' cannot.
The tutorial cases helped!
Thanks for the help!
Old   May 12, 2021, 16:35
Gang Wang
Gang Wang is on a distinguished road
Hi!
Thanks for your nice thread about this issue. I'd like to know how do you set up your back and front surface "transform" type? I feel quite puzzled when setting this, not sure whether "translational" or "noOrdering".
Best,
Gang
Originally Posted by nskelly View Post
Gang Wang is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
