Problem solution with Centrifugall pump dynamic mesh (AIM)
Old   June 7, 2020, 15:35
Unhappy Problem solution with Centrifugall pump dynamic mesh (AIM)
Rodrigo
Rolny is on a distinguished road
Hello forum,
I await everybody be ok.
I need your help with my simulation. Since 2019 I'm trying to simulate a centrifugal pump, based in paper "NUMERICAL STUDY OF PRESSURE FLUCTUATIONS CAUSED BY IMPELLER-DIFUSSER INTERACTION IN A DIFFUSER PUMP STAGE" by F. Shi and H. Tsukamoto.
I'm studying the RSI (Rotor-Stator Interaction), trying to capture the fenomena, obten pressure fluctuation, and calculate the frequency from this.
I'm working with OpenFoam 7, using a dynamic mesh (AIM), with pimpleFoam as solver, and kOmegaSSTSAS (RAS) turbulence model.
When I plot the velocity vectors, I saw a big issue. Inside the stator be recirculating the flow. I attached print with these
Based in paper mentioned, I used the same time step, and I left to my rotor turn 10 laps.
So I have the below questions:
1) Do I making a mistake with the boundary conditions?
2) Maybe, Do I need let the flow inside the volute be ordered with more laps in the rotor?
3) Do I have an general error in my simulation?
I attached the imput files. (Link Google Drive)
Please I need you help to continue with my I+D project.
I thank you in advance for your time and I await your responses so I can continue learning.
Regards!
https://drive.google.com/drive/folde...yh?usp=sharing
Rolny is offline   Reply With Quote
Old   November 29, 2023, 13:36
Pedro Gouveia
unilord is on a distinguished road
Originally Posted by Rolny View Post
Hello forum,
Regards!
Attachment 78229
Hey,
Did you solve your problem? I am facing the same problem, but only when using Non Conformal Coupling (new AMI for OF 11). Also, how did you manage to replicate the pump's geometry? I am using a pump for my master thesis but it has no volute, just the impeller. I would love to add a volute.
unilord is offline   Reply With Quote
centrifugal pump, fluctuating flow, openfoam 7
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 05:27
Dynamic mesh setting problem Youwu FLUENT 7 June 1, 2020 06:47
Dynamic mesh problem entlit FLUENT 0 June 9, 2016 05:19
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling spaceprop FLUENT 5 September 2, 2014 10:43
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
