Problem solution with Centrifugall pump dynamic mesh (AIM) |
Rodrigo
Rep Power: 8 ![]() |
Hello foro,
I await everybody be ok. I need your help with my simulation. Since 2019 I'm trying to simulate a centrifugal pump, based in paper "NUMERICAL STUDY OF PRESSURE FLUCTUATIONS CAUSED BY IMPELLER-DIFUSSER INTERACTION IN A DIFFUSER PUMP STAGE" by F. Shi and H. Tsukamoto. I'm studying the RSI (Rotor-Stator Interaction), trying to capture the fenomena, obten pressure fluctuation, and calculate the frequency from this. I'm working with OpenFoam 7, using a dynamic mesh (AIM), with pimpleFoam as solver, and kOmegaSSTSAS (RAS) turbulence model. When I plot the velocity vectors, I saw a big issue. Inside the stator be recirculating the flow. I attached print with these Based in paper mentioned, I used the same time step, and I left to my rotor turn 10 laps. So I have the below questions: 1) Do I making a mistake with the boundary conditions? 2) Maybe, Do I need let the flow inside the volute be ordered with more laps in the rotor? 3) Do I have an general error in my simulation? I attached the imput files. Please I need you help to continue with my I+D project. I thank you in advance for your time and I await your responses so I can continue learning. Regards! |
openfoam 7 |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
Dynamic mesh problem | entlit | FLUENT | 0 | June 9, 2016 04:19 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[mesh manipulation] Dynamic Mesh Diffusivity Problem | dancfd | OpenFOAM Meshing & Mesh Conversion | 0 | August 29, 2010 11:50 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
