Calculate Total Pressure and Temperature compressible flow |
June 3, 2020, 07:15 |
Rep Power: 8 |
Hi everyone,
can someone tell me a suitable way to calculate the total pressure and total temperature for compressible flow (supersonic)? I have tried it this way in the controlDict for total pressure: Code:
pressure1 { type pressure; libs ("libfieldFunctionObjects.so"); calcTotal yes; calcCoeff no; writeControl adjustableRunTime; writeInterval 5e-5; // Optional entries // Field names p p; U U; psi psi; pRef 0; } probes1 { type probes; functionObjectLibs ("libsampling.so"); region region0; probeLocations ( (100 50 50) ); fields ( U p T Ma rho total(p) ); executeControl writeTime; writeInterval 1; } And I have not found a way to calculate the total temperature. p0 and T0 are known variables in openFOAM, when you use the totalPressure or totalTemperature BC. So it should be somehow possible to access them, but I dont know how. Kind regards, shock77 |
April 26, 2021, 03:35 |
Perfect question
Rep Power: 7 |
I am also waiting some thoughts on this issue.
August 29, 2024, 20:14 |
Rep Power: 3 |
Has anyone managed to find a solution for this one? I saw that openfoam has a isotropic method for the pressure function object, but I'm not sure how applicable that is for shock systems.
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
Total Pressure, Total Temperature Definitions in Compressible Flows | PCFD | Main CFD Forum | 1 | March 1, 2014 04:58 |
Total pressure in real gas (compressible flow) | Bart Prast | Main CFD Forum | 3 | November 14, 2000 11:44 |
